> Can somebody tell me what this does?, flashing light
Coy
post Sep 4 2008, 05:36 PM
I pulled away from a stop sign and noticed this light flashing. I drove right back home, but everything seemed fine. I turned it off and restarted it and now it doesn't flash any more.
Isn't it a brake light?
azbill
post Sep 4 2008, 05:45 PM
It's the parking brake light. The switch was most likely stuck. If the light is off no worries.
Bill
type47
post Sep 4 2008, 05:48 PM
Viermeister
the switch for the brake light is located such that when you release the brake handle, the handle will activate a little push switch and control the light. i've had it so that the handle came down crooked and missed hitting the switch even though the brake was off and the light was on since it missed the switch. it's possible the handle was off the switch and maybe knocked back on and turned the light off.
Coy
post Sep 4 2008, 05:49 PM
Is this place great or what? that took about 5 minutes.
Thanks!
orange914
post Sep 4 2008, 06:03 PM
http://5starmediaworks.com/index.html
QUOTE(Coy @ Sep 4 2008, 04:36 PM) *
isnt the 914 e-brake a grounding switch? the pin being cocked over, flutering the light makes sense. (IMG:style_emoticons/default/agree.gif) i'd test if the light is on solid with the brake pulled and key on. you may have to clean up the contacts... i just wonder what would make it flicker
jasons
post Sep 4 2008, 07:35 PM
Jackstand Extraordinaire
Its also a low pressure warning lamp for the brake system. Check your fluid level in your master cylinder!!!
SGB
post Sep 4 2008, 07:57 PM
just visiting
QUOTE(orange914 @ Sep 4 2008, 07:03 PM) *
Its happened to me- the pin gets wobbly and doesn't get pushed in all the way even though the handle is down.
Dave_Darling
post Sep 4 2008, 09:11 PM
914 Idiot
Nein, nein--das ist der Blinkenlight!
ACHTUNG! ALLES LOOKENSPEEPERS! Das
computermachine ist nicht fuer gefingerpoken und mittengrabben.
Ist easy schnappen der springenwerk, blowenfusen und poppencorken
mit spitzensparken. Ist nicht fuer gewerken bei das dumpkopfen.
Das rubbernecken sichtseeren keepen das cotten-pickenen hans in
das pockets muss; relaxen und watchen das blinkenlichten.
--DD
SGB
post Sep 4 2008, 10:20 PM
just visiting
Hey, ya'll is right, despite them funny werds yous a usin. I just got flashing lights in my eyes and kinda got~ y'know~ goofy....
Not the bigger than side-of-barn flashing light but small, itty-bitty round light.
Like Jason said, all joking aside, check your fluid level and master cylinder.
Coy
post Sep 4 2008, 11:53 PM
Okay, Here's the long story...
I've used my park break a lot in the 4 years that I've owned this car and I've never noticed that light come on once. I didn't even know it was supposed to... I thought it was a failure warning.
The brake reservoir is full, but I didn't take off the floorboard to check the master cylinder yet. In fact I haven't done much, but park it and leave in the pick-up instead. Now I'm back!
Here's the funny part. When I start the car now the light no longer flashes, but I still have a clicking under the fuse box (I'm guessing a bad relay). Anyone know where that wire from the brake system warning light goes through the fuse box and does anyone got a quick guess what would click?
When the brake light was flashing I could hear it; it almost made the same noise as a blinker unit.
I await the wisdom of the club... Non-club... whatever... you smart guys. (IMG:style_emoticons/default/smile.gif)
JRust
post Sep 5 2008, 12:54 AM
You know you only show up here when you need something (IMG:style_emoticons/default/WTF.gif)
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
Okay so back to your clicking noise. (IMG:style_emoticons/default/huh.gif) I got nothin! Sorry (IMG:style_emoticons/default/screwy.gif) Nice to see you on the site though
Coy
post Sep 5 2008, 01:19 AM
QUOTE(JRust @ Sep 4 2008, 11:54 PM) *
No. not only... I sometimes lurk now a days.
computers4kids
post Sep 5 2008, 08:41 AM
Love these little cars!
Coy, these guys are all wet. If you look at page 46 in volume 3 of the service manuals it's very clear your problem and the quick fix.
That light is programed to flash when the driver has not made significant visits to his/her 914world playground either visible or in "lurk mode." So if you really don't want this serious warning light to ruin your next drive, you know what to do. (IMG:style_emoticons/default/laugh.gif)
Steve Snyder
post Sep 5 2008, 08:48 AM
I think the handbrake light is supposed to flash. It is connected to signal/hazard flasher via the black/white wire (might be black/white/green in some cars)... so that sound you heard would be normal.
Cevan
post Sep 5 2008, 10:41 AM
What does the yellow light do? I have one of these gauges in my parts car and I want to install it in my driver and put the CHT gauge in the console.
Coy
post Sep 5 2008, 10:55 AM
QUOTE(Cevan @ Sep 5 2008, 09:41 AM) *
I don't know, but it and the alternator ("G") light both light up when I start the car.
nsr-jamie
post Sep 5 2008, 12:07 PM
914 guy in Japan
Sounds like you need to push the reset pin or button on the master cylinder to stop that clicking sound, take off the cover, slide the rubber boot up and click the reset switch...let me know if that works and how much trouble it was. I will be doing this too when it stops pouring rain here, cheers
Steve Snyder
post Sep 5 2008, 01:09 PM
QUOTE(Cevan @ Sep 5 2008, 12:41 PM) *
The yellow "light" is just a plastic filler lens. It does nothing. In fact, it is held in place by opaque black tape. It is a holdover from early 916/6 cars equipped with a sporto. The combo gauges in such cars had a red lens in that position for the torque converter temp warning (at least, that is what I've read... it's not like I've ever seen a 914/6 sporto combo gauge).
In the gauges with the yellow filler lens, the bulb behind that lens is shielded by a reflective metal tab to provide backlighting for the gauge.
Cupomeat
post Sep 5 2008, 01:13 PM
missing my NY 914 in VA
QUOTE(nsr-jamie @ Sep 5 2008, 02:07 PM) *
The reset on the MC switch is very easy. The hardest part here is just jacking up the front of the car. 4 Bolts for the spash shield and some hand twisting on the MC.
BTW, do you see any RHD 914s in Japan?
Eric
Dave_Darling
post Sep 5 2008, 08:39 PM
914 Idiot
After you know where the button is, you don't need to jack up the front of the car or remove the splash shield. Just crank the steering wheel to the right, reach into the wheel well, find the master cylinder, and push the reset button.
--DD
- Lo-Fi Version Time is now: 5th January 2025 - 12:08 AM
