3 Pages V  1 2 3 >
> Wilhelm's build - Yet Another Machine (YAM), A build starting summer 2008, So how longs this gonna take?
Wilhelm
post Sep 9 2008, 01:12 AM
So its time to quit making parts and start building my car. My true goal despite a bunch of design ideas is to have something I can drive, enjoy, use, and convince the wife to ride in, making it worth the all effort I'm putting into this. I've started with a 74 yellow CA car with fairly mild hell hole rust. The first step was to strip the car of everything, steal all the one-quart freezer bags from the kitchen and label and bag everything I could think of. I threw together a rotisserie out of a bunch of rusty scrap pipe I found in a field. I had the wheels kicking around for years from Harbor Freight. I built this so I could have an off road rotisserie and get the car outside to sandblast it. When all is said and done the sandblasting took about 10 hours with about half that time devoted to heating up the seam sealer with a mapp torch and scrapping it out with chisels and picks. I probably spent and equal time sandblasting remnants of seams sealer to the the time spent on the entire remainder of the car.  One thing that really sped up the sandblasting was to pre-prep large areas with paint stripper; the paint would come off very easily. None of the stripping is fun. Sandblasting requires a respirator, hearing protection (horrifically loud) and eye protection. I initially was wearing a tyvek suit and still got dirty. It also was about 100 degrees out and it got pretty ripe in there. I spent the remainder of the time dressed like in these pictures and all was well and good till the air hose separated from the nozzle and blasted the back of my upper arm. Really friggin hurt and looked like road rash. For eye protection I used the hood shown, then tried a full face shield. What worked best however was using an old welding helmet with a clear lens. The clear lenses would last about 1-2 hours and only cost $.49 to replace compared to a few bucks for the hood and 15 bucks for a shield neither of which had a longer life than the $.49 lens for the welding helmet.
Design goals:
Sheridan front, end narrow body
959 style rear fenders
916 rear bumper
Carbon fiber look top
Monowiper (yeah like rice-a-roni)
Though the hood radiator vent (wbergtho-style)
Front hinged hood
Turbo twist style wheels (8" front, 10" rear)
911 front end 5 lug
928 rear hubs (see my build - 928 Hybrid trailing arm )
Tilt wheel, smaller diameter, thinking from a jetta
Power steering
Move the stereo to where the heater controls are
Air Conditioning with simplified HVAC controls
Coffee cup holders
930 transmission (already have)
Engine- either 327 (already have the 327) versus an LS2
Wilhelm
post Sep 9 2008, 01:18 AM
This crappy old sandblaster was replaced by a http://www.harborfreight.com/cpi/ctaf/disp...temnumber=93889 which worked much better and was able to take a whole 100 pound bag of media.The old style blaster took 15 minutes to fill by a funnel. The new blaster could be filled in 2 minutes. The medium grit would really rip off the seam sealer. The fine grit 70-30 left a nicer finish on the metal. I never felt like metal was going to warp. Got my grit from a lumber yard.
Why can't I ever get a car with no bondo????
Wilhelm
post Sep 9 2008, 01:21 AM
You will get sand in places you didn't remember you had! Like I said earlier, I ditched this hood and went with a welding helmet so a to replace the window in it cheaply when it became etched.
See I have cracked long. Will need a Engman or something similar.
Wilhelm
post Sep 9 2008, 01:28 AM
After much digging out seamsealer and blasting I went to priming early with an epoxy direct to metal primer. If I didn't despite the wicked hot temperatures here I would see surface rust form overnight. I still need a replacement top for the left side shock tower. Any one have a car they are scrapping out and can cut this piece out for me? (Got one from Scotty B - Thanks!!!!!)
Probably hard to appreciate in this picture, but after the engine mounts were taken out (passenger's side was frightenly easy!) I plated up the side of the long with a piece of .125 (13 gauge) with a multitude of holes for bung welding and a continuous perimeter weld. This should give me something solid to hang a V8 off of and will clean up the engine compartment appearance. Also cut out most of the engine shelf as it won't be needed and will just clutter things up.
Wilhelm
post Sep 9 2008, 01:34 AM
I love the smell of napalm in the morning! err I mean I love the look a clean primed out 914! I still have some hell hole repair to do but need to prime when I'm done with a section to prevent flash rust.
Bolted on my new trailing arm 928 Hybrid trailing arm for a fit and put the wheel on. Just hanging the fender to see what it will look like.
Design goals:
916 rear bumper
Front hinged hood
911 front end 5 lug
Power steering
Coffee cup holders
Engine- either 327 (already have the 327) versus an LS6
sww914
post Sep 9 2008, 02:26 AM
Rumor has it that it takes seven years.
I hope you do better than that.
Looking good!
jimkelly
post Sep 9 2008, 06:23 AM
Delaware USA
sweet
i love to see a 914 stripped down to bare metal then freshly primed.
going with stock transaxle? - or going bigger bucks: 915, 930 or G50?
jim
roadster fan
Project Frankenstein !!!!!!!!
Looking good! I am really looking forward to following the build.
Jim
FourBlades
post Sep 9 2008, 07:22 AM
From Wreck to Rockin
Great looking project, should be an awesome car when you are done.
That looks like a very rust free 914 you are starting with which will make things
easier.
I started with a very rusty car and am hoping to be done in about 12-15 months. I knew nothing about 914s or restoration when I started so it may not take you as long.
Good luck....John
neo914-6
post Sep 9 2008, 05:14 PM
neo life
Nice design goals. (IMG:style_emoticons/default/beerchug.gif) Here's some info for reference:
My mono-wiper. It was called ricer too (IMG:style_emoticons/default/laugh.gif)
A clean V8 914 on Car Domain, with power brakes and steering.
tronporsche
post Sep 9 2008, 05:25 PM
That flare and wheel looks good.
Wilhelm
post Sep 9 2008, 05:37 PM
QUOTE(neo914-6 @ Sep 9 2008, 04:14 PM) *
Cool! Thanks for the links. How did you modify the VW mechanism to swing 160 degrees. My guess would be to make the motor swing arm slightly longer.
Also anyone known what other VW power steering units would exchange with the Corrado unit? I will be going to a pick and pull next week next week and want to have a couple of options.
r_towle
post Sep 9 2008, 07:30 PM
Custom Member
I love that rear fender...what is it from???
Rich
jd74914
post Sep 9 2008, 08:15 PM
Its alive
993 Turbo S maybe?
Lou W
post Nov 30 2008, 05:55 AM
Region Association: Spain
Wilhelm
post Dec 8 2008, 07:04 PM
Seems like I've been working on a million little project but today did a few fun things. One was to build this stand to set car on while I fit engine. What I like about this is it only cost for the 4 nuts. Everything else was salvage. I made this adjustable as the floor in the barn is anything but level. With this stand the car can be leveled out to help get the engine in somewhat square.
This is about the only nice thing about a wooden floor (well, I guess its not cold like concrete); I can screw the stand down so it doesn't skid out.
Here are the screw tops. Some salvage all thread. Who the heck welded those nuts in????
Wilhelm
post Dec 8 2008, 07:11 PM
Today I Decided to do some test fitting of the engine into the bay Looks like trying to put 10# of mud in a 5# bag.
Rear entry shot
View from the top
Wilhelm
post Dec 8 2008, 07:15 PM
With the engine harmonic balancer 1/2 " from the firewall, the trans mounts are back about 1 1/2". If I used a corvette balancer I could move the engine another .4" forward I believe.
Here is front of engine. Balancer is 1/2" from the firewall
Design goals:
Sheridan front, narrow body
916 rear bumper
Front hinged hood
911 front end 5 lug
Tilt wheel, smaller diameter, thinking from a chevy (The jetta wheel wouldn't work)
Power steering
Coffee cup holders
Engine- LS2
JRust
post Dec 8 2008, 08:46 PM
Making good progress! I'll have to find out where hooterville is & come by some weekend to see it up close (IMG:style_emoticons/default/biggrin.gif)
Maybe I can even drive my 914-8 (IMG:style_emoticons/default/driving.gif)
So.Cal.914
post Dec 8 2008, 09:04 PM
"...And it has a front trunk too."
QUOTE(JRust @ Dec 8 2008, 06:46 PM) *
You know 'Green Acres' , Eddie Albert and Eva Gabor. (IMG:style_emoticons/default/smile.gif)
Nice work so far, couldn't you find a bigger engine? (IMG:style_emoticons/default/av-943.gif)
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 25th April 2025 - 07:26 PM
