Decel Valve taken apart...., pics..... |
415PB |
Feb 4 2004, 06:48 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
I got off from work early today and thought I would finish up my alluminum sunvisor mounts, I was wrong. I picked up an extra decel valve and decided to open it up. I plugged mine because It was all jacked up. I know most dont use their decel valve anymore, but thought if nobody had opened one up and posted it here before, this might help the ones that still have them.
Attached image(s) |
415PB |
Feb 4 2004, 06:49 PM
In pieces:
Attached image(s) |
415PB |
Diaphram was in good shape considering it is 30 years old.
Attached image(s) |
415PB |
Feb 4 2004, 06:50 PM
Top portion with the adjustment tube
Attached image(s) |
415PB |
Feb 4 2004, 06:51 PM
and back together again after a really good cleaning, some crimping and JB Weld.
Attached image(s) |
Brad Roberts |
Feb 4 2004, 06:56 PM
See how far you can throw it.
Just kidding. Interesting that they used a diaphram almost identical to a carb accelerator pump diaphram. B |
415PB |
Feb 4 2004, 06:58 PM
(IMG:style_emoticons/default/laugh.gif) I almost did Brad. Figured I didn't need the damn thing, why not screw it all up by taking it apart.
Joe Bob |
Feb 4 2004, 06:59 PM
Yah,.....give it the "float test"......
busaslidr |
Feb 4 2004, 10:07 PM
Newbie Group: Members Posts: 33 Joined: 3-January 04 From: San Diego, CA Member No.: 1,503 |
Why would one want to remove the decel valve, for what purpose???
swood |
Feb 4 2004, 10:30 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Is that an early decel valve? Mine on the '75 was more of a flattish disk kinda thing.
72914S |
Feb 5 2004, 11:22 AM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
Decel valve? I thought that was for fuel pressure, at least thats where I adjusted mine. (IMG:style_emoticons/default/confused24.gif)
Dave_Darling |
Feb 5 2004, 11:49 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That is a decel valve, the FPR is similar. The 1.8 FPR has three fittings on it (fuel in, fuel out, manifold vacuum) and is not adjustable; the 1.7 and 2.0 FPR has two fittings (fuel in, fuel out) and is adjustable. The adjustment on the DV looks like the one on the FPR, but the fitting is much bigger on the FPR.
The 1.8s (except possibly some very early ones) had the flat disk skaped DV. The one shown here is a 1.7 or 2.0 one. (Or maybe that early 1.8.) The DV got hard to find a while back, so it is possible that the 1.8 one was retrofitted to other systems. I think the 1.8 version was still available for a good while longer because of its use in the Bus engines. --DD |
busaslidr |
Feb 6 2004, 12:27 PM
So what does a decel valve do??
Joe Bob |
Feb 6 2004, 12:47 PM
Keeps the throttle from slapping shut too fast, leaving unburned fuel in the system....aka "smog shit".... (IMG:style_emoticons/default/blink.gif)
swood |
Feb 6 2004, 06:49 PM
So is it better to have than not have?
airsix |
Feb 6 2004, 07:17 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(busaslidr @ Feb 6 2004, 10:27 AM) So what does a decel valve do?? It momentarily bleeds air into the intake when you snap the throttle shut. This reduces emissions but also makes the rpm's fall SLOWLY when you close the throttle. The only benefit to drivability is it keeps the rpms from dipping below idle speed when you snap the throttle shut quickly. The downside is this makes shifting slower, and adds more work/wear to the tranny syncros (IMHO). Some take their decel valve off and throw them away. Personally I think that's the wrong approach. You should take it off and hit it with the biggest hammer you can find. Then throw it away. -Ben M. |
swood |
Feb 6 2004, 07:34 PM
QUOTE(airsix @ Feb 6 2004, 05:17 PM) Some take their decel valve off and throw them away. Personally I think that's the wrong approach. You should take it off and hit it with the biggest hammer you can find. Then throw it away. -Ben M. (IMG:style_emoticons/default/laugh.gif) Well put! |
Lo-Fi Version | Time is now: 28th December 2024 - 02:46 PM |
