Todd Enlund |
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest ![]() |
I'm going to need a fuel pump for carbs. Any suggestions? I've heard mixed opinions on the Facet pumps. I'm looking at Holley pumps on eBay... are they robust enough that I can think about buying a used one? And then there's the question... mount it by the gas tank, or in the engine bay?
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
I think they are robust enough but are presett to run 8 to 9 psi. So you will need a fuel regulator to drop it to 3.5 psi. Maybe better to find a pump self regulated at 3.5 psi. If your going to have the car all apart, might as well mount it up front. (IMG:style_emoticons/default/bye1.gif)
Steve |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Peerburg pump. Already runs the correct pressure for a set of webers, and is quiet. Mount it up front by the tank. It will work better pushing than it will pulling.
At Zims, we put them on old 911s when the factory bosch pump goes out. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
You can't PULL a liquid!
Todd Enlund |
Peerburg pump. Already runs the correct pressure for a set of webers, and is quiet. Mount it up front by the tank. It will work better pushing than it will pulling. At Zims, we put them on old 911s when the factory bosch pump goes out. This one? Pierburg Fuel Pump |
ClayPerrine |
Peerburg pump. Already runs the correct pressure for a set of webers, and is quiet. Mount it up front by the tank. It will work better pushing than it will pulling. At Zims, we put them on old 911s when the factory bosch pump goes out. This one? Pierburg Fuel Pump That's the one!!! I am going to use it on my 911 when I finally put the engine in it. |
Todd Enlund |
You can't PULL a liquid! Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) I was leaning towards front mount anyhow, if for no other reason than the pump would be better protected. |
southernmost914 |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
That's a good price, my cost is $85 for them. I got one sitting in will call for my 914. Glad I checked this thread! (IMG:style_emoticons/default/biggrin.gif)
Todd Enlund |
That's a good price, my cost is $85 for them. I got one sitting in will call for my 914. Glad I checked this thread! (IMG:style_emoticons/default/biggrin.gif) They tack on a $4 handling charge (IMG:style_emoticons/default/dry.gif) But then shipping is only $4.80. I might have to go for this when the time comes. |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I'm running a CB rotary pump. Quiet and internally regulated.
Todd Enlund |
biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
I'll be using a CB perf. too... Justinp71 has one running his new 3.0 6 and its quiet and gives a constant 3.5 according to his gauge.
Root_Werks |
The CB pump would probably work great as well, but I already have the other sitting for me to pick up. Since my 914 is a 74' and the wiring is already back there, I'll just leave it in the back and mount it up. I plan on having a pressure regulator in place as well and hooking the return line up etc.etc.
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
So far so good with my CB pump. Mine is mounted where the original fuel filter was...
Root_Werks |
yeahmag |
I got mine a long time ago, but it looks like they are $55.00
http://cbperformance.com/catalog.asp?ProductID=577 |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
One more for the CB Performance. They've given me yeas of quiet service on a variety of different cars and never a problem. And it's nice not to need a separate pressure regulator. Used the Holley one time, never again.
Elliot Cannon |
[quote name='Todd Enlund' date='Oct 24 2008, 12:59 PM' post='1094538']
[quote name='Elliot Cannon' post='1094533' date='Oct 24 2008, 11:54 AM'] You can't PULL a liquid! [/quote] Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) That's exactly my point. If the pump is lower than the tank, the static pressure to the pump is the same, weather the pump is in the front or the back. |
Root_Werks |
[quote name='Elliot Cannon' date='Oct 24 2008, 03:46 PM' post='1094600']
[quote name='Todd Enlund' date='Oct 24 2008, 12:59 PM' post='1094538'] [quote name='Elliot Cannon' post='1094533' date='Oct 24 2008, 11:54 AM'] You can't PULL a liquid! [/quote] Yeah, but if the pump is lower than the tank, it could still be located in the engine bay... fuel would run to the engine bay even without a pump (IMG:style_emoticons/default/biggrin.gif) That's exactly my point. If the pump is lower than the tank, the static pressure to the pump is the same, weather the pump is in the front or the back. [/quote] Yup, being a Boiler Sup and dealing with Hydronic loops/pumps all day, liquid doesn't lend to being sucked or pulled very well. Loves to be pushed as we all know it's a non-compressable. (IMG:style_emoticons/default/wink.gif) I'll move my pump to the front at some point. But not right now. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:34 AM |
