bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
I have the 73 1.7 that came with the single Solex 2bbl carb. I can't afford to do the engine rebuild probably until summer. I also have in the box a set of twin (both sides) Dellorto 36 carbs. I know the car runs bad using the Solex. I know the car won't run right with the Delortto's and the stock cam. The FI is mia and the PO said no chance of recovery.
Is there anything to gain right now puttin on the Dellortos or should I just wait until motor rebuild time? (IMG:style_emoticons/default/blink.gif) Thanks |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I have the 73 1.7 that came with the single Solex 2bbl carb. I can't afford to do the engine rebuild probably until summer. I also have in the box a set of twin (both sides) Dellorto 36 carbs. I know the car runs bad using the Solex. I know the car won't run right with the Delortto's and the stock cam. The FI is mia and the PO said no chance of recovery. Is there anything to gain right now puttin on the Dellortos or should I just wait until motor rebuild time? (IMG:style_emoticons/default/blink.gif) Thanks Yes. A lot to gain. Do it now. Today. Get them on, balanced, and you should notice an improvement. Zach |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Yes the cam is wrong but the two 36's , as said above should run better.
Lo-Fi Version | Time is now: 25th June 2024 - 12:48 AM |
