echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
I removed a pair of rear hubs from a 71 911. One gave pretty easily with the Eric Shea method using an old tbar and a BFH.
the other one took a whole lot more convincing to come loose. After about an hour of whacking with the tbar and BFH I switched to a impact socket that fit nicely in the partially removed bearing. With the torsion bar and the socket I mashed the back of the hub a bit. Is this gonna be a problem when reusing the hub? |
Rich Bontempi |
914 Road Racer ![]() ![]() Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California ![]() |
If you mashed the edge of the hub that rides against the wheel bearing or the edge that rides against the stub axle, you could have issues with play developing. That wouldn't be a good thing.
echocanyons |
it is the edge that rides against the stub axle
Should I sand it down to clean it up? |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Yup....
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Should I sand it down to clean it up? Do you have a die grinder? I'd use a variable speed grinder/drill with a round stone bit. Probably should clean it up a bit. Sometimes they come out with a nice clean whack and sometimes they're impossible. Sounds like you got the best of both worlds. |
echocanyons |
Thanks again for the tip Eric, I would not have budged them otherwise
there was a bit of rust on the hub to bearing surface, Im sure this was the reason. I will clean it up with a die grinder. |
Eric_Shea |
QUOTE there was a bit of rust on the hub to bearing surface, Im sure this was the reason. I will clean it up with a die grinder Make sure you don't use the die grinder on the hub to bearing surface (IMG:style_emoticons/default/smile.gif) (prolly knew that already... (IMG:style_emoticons/default/blink.gif) ) |
echocanyons |
Yup dont wanna do that
Lo-Fi Version | Time is now: 20th June 2024 - 09:17 AM |
