Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
I went to pop the front lid and the handle broke. O.K. so I dug up another handle and went to exchange key cylinders. the broken orginal comes out fine with the key but the unknown has no key. I tried all of the 20-30 keys I have...still can't get it removed. Is there a secret password or something short of a local locksmith?
Triaddave |
Is there anybody out there who has done this?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,997 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
There's a little tiny set-screw in the part of the handle that is inside the housing until you pull on the handle. (I hope I'm not being too confusing about that!) Pull the handle out far enough and you should be able to see it. Put any key in the slot, remove the screw, and the lock cylinder should slide out. Do the same with the old handle so you can put its lock in the new handle.
--DD |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
question, mine never worked.
What key is supposed to do the front hood lock and the glove box?? Rich |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
My Key opens everything.
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
As they stated above, one key should fit all. If not, then look at my signature for how to rekey yours.
So.Cal.914 |
Oh for God's sake how could you expect any different. You know I'm a Freak. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:08 PM |
