dlestep |
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States ![]() |
...I've been looking at different stuff, like
Moly 60, Optimoly, Lubriplate, Kendall... What's new? What's good? What are you using? |
johnnie5 |
914 lover ![]() ![]() Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California ![]() |
Good question. I am going to rebuild/regrease/reboot all four of my CV's this weekend. I was going to use high heat red moly grease? Any brandname recomendations?
familienauto |
Volksporsche ![]() ![]() Group: Members Posts: 136 Joined: 5-November 06 From: UW Seattle Member No.: 7,156 Region Association: Pacific Northwest ![]() |
Last time I did a CV was on my Ghia. I just used the CV moly grease on the shelf at NAPA. Black and smells terrible. No problems after a few thousand miles.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Swepco
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Considering that my axles will likely be apart in the next 5-7 years anyway... I used the cheapest moly grease available at my FLAPS. (IMG:style_emoticons/default/smile.gif)
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
Swepco 101 or LubroMoly CV Grease.
(IMO - 5 years between CV service is WAY too long...) My standard mantra: CV's have a hard life in 914's, especially the inboads. Aft of the engine, directly above the exhaust. Cheap grease will turn to clay from the heat. Grease is not expensive but the job is pretty unpleasant so you don't want to be doing it any more often than you need to. Couple that with hard-to-replace CV's and the result is: use good grease... |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
SWEPCO
dlestep |
...after looking into this I found that the low price cv grease may have 3% MoS2, whereas the other expensive brands have upwards from 40% to 60%.
I purchased GKN Automotive's Schmierfett fur Gleichlaufgelenke (MoS2). Which loosly translated means MooSe shit on a stick. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
swepco or if I get the Lobro boot kits the grease that comes with it is fine.
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE CV's have a hard life in 914's, especially the inboads. Aft of the engine, directly above the exhaust. Cheap grease will turn to clay from the heat. Grease is not expensive but the job is pretty unpleasant so you don't want to be doing it any more often than you need to. Couple that with hard-to-replace CV's and the result is: use good grease... Could have said it better myself... so I didn't. Thanks Rich! (IMG:style_emoticons/default/biggrin.gif) http://www.pmbperformance.com/catalog/item...868/6620271.htm |
Lo-Fi Version | Time is now: 27th June 2024 - 08:58 PM |
