eg914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None ![]() |
Pulled the trans for an oil seal replacement, and my clutch disc is down to the rivets on the pressure plate side. I thew in an old disc to keep me going (daily driver).
My question is, can I reuse the flywheel I have, or does it need to be resurfaced or replaced? How can I tell if the flywheel is OK to use as it is? Seems like the Pelican and AA kits can include flywheels, but that adds a bit to the cost. Just trying to figure out what the hit to the budget is going to be. Thanks |
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
You should at least resurface it to keep it from grabbing and smooth operation. Keep in mind these are 30+ year old flywheels and most likely have been machined before. I do not know the specs but you would have to spec it after machining. It better and cheaper in the long run to do it right than do it twice. (IMG:style_emoticons/default/biggrin.gif)
Steve |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Just make sure the face has not been cut so much that the clutch disc center rubs on the F/W center bolts.
eg914 |
Thanks for the replies. Guess I will have to spend the bucks for a flywheel. I can't afford much down time when it comes to replacing the clutch. The flywheel is in the car now, and I probably won't have time to get it surfaced locally.
If I install a different flywheel will I need to check the end play of the crankshaft, or is that flywheel independent? |
So.Cal.914 |
I would check it for sure.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
You must check the end play if you change flywheels, good thing to check even with the same flywheel. You also should replace the flywheel seal and O-ring. If you have your ducks in a row with a good machine shop they should be able to grind your flywheel while you wait.
I wouldn't do it now, but on a tight budget I've reused a flywheel as long as the friction surface is flat (using a straightedge) and not glazed or burnt. BTDT |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
You must check the end play if you change flywheels, good thing to check even with the same flywheel. You also should replace the flywheel seal and O-ring. If you have your ducks in a row with a good machine shop they should be able to grind your flywheel while you wait. I wouldn't do it now, but on a tight budget I've reused a flywheel as long as the friction surface is flat (using a straightedge) and not glazed or burnt. BTDT Yep, what Mark said... Post some pics of it and I can tell you whether it has another "life" left in it for machining (more than likely) |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Jake, can you tell from this pic if the flywheel can be turned? I believe it only has 110K on the engine and I can't tell if it has ever been turned.
There is a deep groove on the outer circumference of the contact surface. It matches the light colored ring, about a 1/4" wide on the outer circumference of the disc. Since there are no rivets out there, I can't figure what made the ring. Clearly the flywheel should have been turned before this disc was installed. ![]() ![]() |
Jake Raby |
It looks low, but **may** have one more life in it... Have it measured.
Porsche Rescue |
Can you tell me the spec? Search here is unclear. Some say 11mm (disc surface to mounting surface) and others say 7-8mm. I know the plate mount surface and disc surface must be maintained at 22.5.
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
You will probably be ok as long as there is still a "step" left from the working surface toward the inner atachment.
Lo-Fi Version | Time is now: 20th June 2024 - 11:41 PM |
