72914S |
love this shot ![]() ![]() ![]() Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States ![]() |
Don`t think this will fit under the lid. http://www.thesamba.com/vw/classifieds/detail.php?id=727571
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
a bug is lighter than a 914 and a drag bug is much lighter.
for 8500 beans - you could get a sweet raby powerplant - better suited to a 914 is my understanding wll it fit - height will be a problem jim |
dinomium |
Git on a chair son, all the good stuff is goin over yer head! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest ![]() ![]() |
and exhaust might be and issue as well...
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I could maybe believe 150-200 hp with a little reliable service. Vw didn't design the case or crank design to hold up to 400hp. To use strengthened parts to hold that hp reliabily would cost twice that.The same heat is made on any motor that makes 400 hp. Can you imagine cooling that without water? Sure 8 second passes but 3,4 or 5 minute full blast in the dunes?
It sure won't have any oil residue on the outside unless a new port opens up. 2 liter bug head designs must need 30-35 lbs of boost to make that amount of hp. When you bring it back to reason a raby na motor would be a much better proven solution. |
72914S |
I really wasn`t considering it but I did like the thought. I`m sticking to my 2056 w/ F.I.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Grenade!
That would be like a 2 stroke race motor, rebuild it one weekend, run it the next, repeat. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:37 AM |
