Will these repro fuchs fit? |
turnaround89 |
Jan 21 2009, 02:30 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Will these fit under my fg flares?
Fuchs |
cobra94563 |
Jan 21 2009, 03:31 PM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Same offsets as originals, so they will fit if you have flares.
Awhile back, I asked one of the vendors if they could just send (4) 8 inch rims, instead of 7/8's, and he said no problem. Because with my 7's in front, I use a 1 inch spacer that would not be required if I had 8's in front. (I ended up buying them elsewhere.) Worth asking if you want to do that. |
my928s4 |
Jan 21 2009, 11:34 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
How do those 8" rims fit out back? I thought you could go 9?
I like the same width all round though, easy to rotate. Chris |
carr914 |
Jan 22 2009, 07:47 AM
Racer from Birth Group: Members Posts: 119,313 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
kconway |
Jan 22 2009, 08:59 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
TC-
Any spacers required when using 15x8's on all 4 corners on a flared car? What color blue is that? Kev |
carr914 |
Jan 22 2009, 02:07 PM
I'm not quite sure of the color, it's darker than the original Ancona Blue (which it will go back to) and has A Lot of metal flake in it - kinda like a Glastron Bassboat
I've never used spacers with 8"s all around, though you could space the rears out to fill out the flares. Here is one of my former cars with 15x8's in front & 16x8"s in the rear - no spacers T.C. |
turnaround89 |
Jan 22 2009, 02:35 PM
I purchased the rims and now i will save for tires. Any suggestions on good tires? Looking for a summer/spring driver so all weather tires aren't needed, more of a high performance tire would be best. Once i get tires i will get them on the car for test fit and see how that goes. I won't leave them on the car for fear of ruining them while doing all the bodywork, grinding, welding, etc on the car. So the old rims will stay on the car for awhile until the car is "done" (IMG:style_emoticons/default/dry.gif) if that ever happens
Carr914 - the color of your former car, do you know what color blue that is? Not the light blue on the headlight, but the front bumper and looks like the rest of the car body color? Thanks |
carr914 |
Jan 22 2009, 05:54 PM
The Color on my former car is a Porsche color (but not a 914) called Cobalt Blue. It was used on 968s and I believe is a current color for 997s.
This picture has 8"s & 10"s T.C. |
turnaround89 |
Jan 23 2009, 12:39 AM
Thanks, there might be another cobalt blue914 running around in a little bit. Won't look like yours bc i have 916 stuff on mine, Great looking car by the way!!!!
carr914 |
Jan 23 2009, 07:01 AM
Any suggestions on good tires? Looking for a summer/spring driver so all weather tires aren't needed, more of a high performance tire would be best. Once i get tires i will get them on the car for test fit and see how that goes. I won't leave them on the car for fear of ruining them while doing all the bodywork I like BFG G-Force Sports. Nice grip, good tread life, not expensive. And get a set of cheap cookie cutters or borrow a set while you are doing bodywork. T.C. |
turnaround89 |
Jan 23 2009, 03:12 PM
Already got a cheap set of rims for the bodywork. There are adaptors on the car now, but 5 lug will be going on soon. Once the 5 lug goes on ill put the cheap rims on to finish the bodywork and after the car is painted the fuchs will go on!!
I looked at those tires, they seem like a good set to run. My buddy works at sears and he said he would personally mount and balance the tires. Thank God, bc i trust him and don't want someone to screw up a brand new set of rims. They may be repros, but i dropped a good amount of green to care a lot about them and to not have someone ruin them!!! |
Lo-Fi Version | Time is now: 26th June 2024 - 12:59 AM |
