Aftermarket TypeIV motor mounts, ...anyone have lightweight solid mounts? |
Chris Hamilton |
Jan 22 2009, 05:40 PM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Anyone here have leads on aftermarket motor mounts? I think I remember SirAndy having one made of box chromoly when he was still running a 4-banger. I'm looking for something solid and lighter than the stock bar.
Mark Henry |
Jan 22 2009, 05:48 PM
For the rubber mounts I wouldn't run anything but the stock mounts unless it's an all out race car. As for the bar you could fab up a bar that's lighter, but to be strong enough the weight savings would be small.
Chris Hamilton |
Jan 22 2009, 08:02 PM
For the rubber mounts I wouldn't run anything but the stock mounts unless it's an all out race car. As for the bar you could fab up a bar that's lighter, but to be strong enough the weight savings would be small. Yeah, I'm looking for a bar that's lighter than the stock one. This is for my trailered racecar, you might have seen it before: (IMG:http://www.thextremeresources.com/boshi/images/cars/aX1.jpg) |
Aaron Cox |
Jan 22 2009, 08:04 PM
Make a pair on the lathe, shouldnt take you more than a half hour (IMG:style_emoticons/default/smile.gif) (assuming you have a sideshift)
SGB |
Jan 22 2009, 08:29 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Its been done. I think the weight savings were pretty minimal , as stated above. Seems like it wasn't even a full pound in reduced weight.
McMark |
Jan 22 2009, 08:38 PM
I wonder is a T bar would make it lighter. Four tubes for bolt passthrough, flat plate on top parallel to the ground, flat plate vertical.
I bet that would do it, and weight a lot less. (IMG:style_emoticons/default/idea.gif) I have a mount bar laying around here. I could whip up a prototype... (IMG:style_emoticons/default/welder.gif) |
Chris Hamilton |
Jan 23 2009, 09:44 AM
McMark that sounds interesting. I'm not sure what you mean though, you're talking about a motor mount like the -6 has?
Also anybody remember SirAndy's motor mount back when he had a type IV? |
J P Stein |
Jan 23 2009, 10:08 AM
This is for my trailered racecar, you might have seen it before: Ayup, sure is ugly. (IMG:style_emoticons/default/biggrin.gif) Pretty quick tho. 2nd place material. |
ChrisFoley |
Jan 23 2009, 11:06 AM
I am Tangerine Racing Group: Members Posts: 7,969 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Why would you want to lighten one of the lowest parts of the car? That will raise your cg.
McMark |
Jan 23 2009, 01:22 PM
Here's a mockup design.
Attached image(s) |
ericread |
Jan 23 2009, 01:29 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
How does your design ensure there is no rotational flex, or do you feel this is not an issue? Do you believe this design can meet the stock design of keeping the engine in a very static position?
(IMG:style_emoticons/default/idea.gif) |
McMark |
Jan 23 2009, 01:45 PM
Eric, rotational stress along the length should occur between the center and the ends. There will never been end to end torsion, because the body is relatively solid (for the purposes of this design study). So you have a 1.75' section that's twisting, which is pretty short. I think the T-structure will provide sufficient strength.
Torsion comparisons between this design and the stock bar would be fairly easy to conduct. Drilling holes would also be an option that could be tested.... |
ericread |
Jan 23 2009, 01:47 PM
Eric, rotational stress along the length should occur between the center and the ends. There will never been end to end torsion, because the body is relatively solid (for the purposes of this design study). So you have a 1.75' section that's twisting, which is pretty short. I think the T-structure will provide sufficient strength. Torsion comparisons between this design and the stock bar would be fairly easy to conduct. Drilling holes would also be an option that could be tested.... Cool (IMG:style_emoticons/default/aktion035.gif) So how much weight do you anticipate saving? |
Mark Henry |
Jan 23 2009, 02:17 PM
You will need a hole for the shift rod.
J P Stein |
Jan 23 2009, 07:03 PM
BTW, if ya'll want a rematch, it'll be at Packwood WA, August 8 & 9.
Ya'll come to our house & lay a whippin' on us'n & we'll call it even. (IMG:style_emoticons/default/biggrin.gif) I think Andrew remembers this car. Attached image(s) |
Chris Hamilton |
Jan 24 2009, 07:06 PM
BTW, if ya'll want a rematch, it'll be at Packwood WA, August 8 & 9. Ya'll come to our house & lay a whippin' on us'n & we'll call it even. (IMG:style_emoticons/default/biggrin.gif) I think Andrew remembers this car. Yeah I remember that second place you got to our first on sunday (IMG:style_emoticons/default/biggrin.gif) As I remember it we're already tied (BMWs don't count dammit ) How about a rematch without tire warmers? (IMG:style_emoticons/default/driving.gif) |
Chris Hamilton |
Jan 24 2009, 07:09 PM
Why would you want to lighten one of the lowest parts of the car? That will raise your cg. I'm not too worried about the CG when the whole car needs to be lighter. By that logic we should be adding lead panels to the floors to lower the CG. Overall weight is a much more important factor right now. |
J P Stein |
Jan 24 2009, 07:21 PM
BTW, if ya'll want a rematch, it'll be at Packwood WA, August 8 & 9. Ya'll come to our house & lay a whippin' on us'n & we'll call it even. (IMG:style_emoticons/default/biggrin.gif) I think Andrew remembers this car. Yeah I remember that second place you got to our first on sunday (IMG:style_emoticons/default/biggrin.gif) As I remember it we're already tied (BMWs don't count dammit ) How about a rematch without tire warmers? (IMG:style_emoticons/default/driving.gif) Well the event was cumulative times for 2 days just like the SCCA does at the Nationals, but Andrew did a fine come back on day 2....... but not enuff to make up for the first day's ass kicking. Sure, no tire warmers and no changing the car for day 2. (IMG:style_emoticons/default/biggrin.gif) Brit's unfortunate cones after the lights on his last run let both you'z guys and the Beemer thru on day 2. We did OK for our first time on concrete *at your house*. |
Chris Hamilton |
Jan 25 2009, 12:52 PM
McMark |
Jan 25 2009, 09:01 PM
Clearance for the shifter wouldn't be too big of a deal. I'm searching for appropriate 'tubes' for the bolts to pass through.
Lo-Fi Version | Time is now: 5th January 2025 - 01:45 AM |
