underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
OK, last summer bought a 73 supposedly with a 1.7. Thats what i assumed. Finally was able to read the engine number and it a GE case. Everything I have found says its a very late 2.0 ??!! It has the stock injection on it and 4 bolt intakes. The motor I have on a stand came out of a bus and has a CB on it. That one seemed to make sense, 1.7 dual carbs. What the (IMG:style_emoticons/default/headbang.gif) is a GE case???
Todd Enlund |
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest ![]() |
OK, last summer bought a 73 supposedly with a 1.7. Thats what i assumed. Finally was able to read the engine number and it a GE case. Everything I have found says its a very late 2.0 ??!! It has the stock injection on it and 4 bolt intakes. It's a 2.0 case, but it's a bus 2.0... very different animal. The motor I have on a stand came out of a bus and has a CB on it. That one seemed to make sense, 1.7 dual carbs. Bus 1.7... |
ws91420 |
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region ![]() |
2.0 L bus Hydro cam engine that would explain the 4 bolt intake on a 2.0
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Could still be a 1.7, they may have just used a bus case during the rebuild. Check the numbers on the heads and this site can help you figure it out:
http://www.tunacan.net/t4/index.shtml |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Pull a lifter out to see if its hydraulic or solid...GE were 79 (hydro) Bus engines rated at 67hp..low compression pistons with huge dishes...
But as Mark says check the heads numbers....... Sell those dual bus carbs on the Samba as lots of Bus guys want those!!!! |
underthetire |
Thanks all. It sure is a hydraulic lifter unit. I kept thinking "why those guys always adjusting valves" Now I know, I got a POS bus motor!!!!
Mark Henry |
That sucks, but your're not the first to find a bus motor in a teen.
Watch the classifieds as a complete engine often comes up, sell the bus engine to recoup some of your money. |
underthetire |
I probably will eventually. This engine seems to have a lot of torque and it runs nice and uses no oil at all. Maybe next winter.
Lo-Fi Version | Time is now: 1st July 2024 - 03:21 AM |
