Anyone ever used this?, Weltmeister Shift Lockout Kit |
turnaround89 |
Feb 18 2009, 12:53 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Just wanted to know if anyone has any opinions on the shift lockout kit, does it help? How hard is the install? For $50, it may be worth it and my reverse gear may thank me.
I have all new bushings and the shifting seems to be as good as possible for a tail shifter but every now and then i clip reverse and im getting sick of it. Will this help? Or should i just save and transform my car to side shift, don't really want to since it is the original trans still in the car and i don't want a trans sitting in the garage taking up useful space! |
SirAndy |
Feb 18 2009, 01:10 AM
Resident German Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Reverse is sooooo way out of the way on the 901, i don't see how this would do you any good ...
If you're hitting reverse on downshift, you might want to invest in some new shift bushings instead. (IMG:style_emoticons/default/shades.gif) Andy EDIT: Ok, tailshift. That explains it ... |
turnaround89 |
Feb 18 2009, 01:25 AM
already have the new bushings installed.
im not clipping reverse on a downshift, im clipping it when shifting from 1st to 2nd. |
JoeSharp |
Feb 18 2009, 05:08 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I have one and it did help but I found if I don't try to get into second so quickly it helps more. I'm going to put that kit in my race car just because of the load it takes to get it into 1st and reverse.
914Sixer |
Feb 18 2009, 07:54 AM
914 Guru Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will need to take a old screwdriver and make it into a compression tool for the springs. Kit says will require you to enlarge holes for new pins and springs. Spring compression is tricky and can be dangerous.
rhodyguy |
Feb 18 2009, 10:06 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
is this an actual part that blocks the slot for reverse or just an additional set of stouter springs?
k |
turnaround89 |
Feb 18 2009, 02:45 PM
Joe Sharp - you mentioned the load it takes to get into reverse and 1st, are you saying it is harder to get into those gears when you move the shifter all the way over?
I think it is just a stouter set of springs |
maf914 |
Feb 18 2009, 03:57 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Actually it is an additional pair of springs and it was a tough install, trying to compress those onto their mounting pins. They took flight across my garage more than once.
This was many years ago, pre-internet days, and limited access to experienced 914 people. I had noticed my shifting was getting vague, so I replaced the shift bushings. This didn't solve the problem, so reading my Automotion catalaog I decided to try the spring kit. It didn't solve the problem either, but in trouble shooting I finally fiound the main culprit, the shift rod universal joint bushings had disintegrated, literally. Replaced those and the shifting problem was cured. And the spring kit gave the shifter a stronger push away from reverse on the 1-2 shift. Necessary? I don't think so, but not bad. |
rhodyguy |
Feb 18 2009, 05:46 PM
the kit springs increase the effort to move the reverse lock out plate (new ones are $19.50 from the bird. aa has them too) substancially. this promotes wear on both the plate and the spot on the shift lever that contacts the plate. ease up on the shift speed from 1st to 2nd. examine the plate contact edge and replace if worn. while the shifter assem is apart, replace the 2 bushings that cradle the pivot ball on the shift lever. those 2 are often overlooked during the rebushing process and they can make a noticable bif in the quility of the shifting.
k |
Steve |
Feb 19 2009, 01:23 PM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I installed it in my car when they first came out years ago. The bigger springs pretty much eliminated the accidental hitting of reverse going into second. I think it also built up my forearm everytime i shifted into first.
Lo-Fi Version | Time is now: 20th June 2024 - 06:23 AM |
