number6 |
Member ![]() ![]() Group: Members Posts: 352 Joined: 14-September 08 From: portland, or Member No.: 9,546 Region Association: Pacific Northwest ![]() |
OK, as it turns out, I do have a valid oil tank question! Sorry, everyone, for the multiple post changes!
What would be the best way to determine total oil capacity in my car? It is a /6 conversion with a 3.2, aftermarket oil tank (a Velios, I believe), and NO front-mounted oil cooler. I do have a Patrick Motorsport breather tank. I ask because I don't think the dipstick I have is accurate. My tank's bundled dipstick was broken, so the seller ordered me a replacement from Auto Atlanta (which appears to be a replacement for the factory tank). My thinking is to drain my oil and add back 9 quarts to see where/if it registers on the dipstick that I have. From reading through the archives, I came across this discussion: http://www.914world.com/bbs2/index.php?sho...5&hl=velios There's mention of 11 quarts max...but also 13, 14, and 15 quarts... And just to make doubly-sure: A dry sump system can't be damaged with overfills, no? Excess oil would simply drain out (through my breather tank drain) and/or burn off? Thank you for any advice! -duc |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
A quick search through the search engine. Brings this up, doesnt answer your questions exactly but should help. There are many others threads with more info.
Search result |
number6 |
A quick search through the search engine. Brings this up, doesnt answer your questions exactly but should help. There are many others threads with more info. Search result Thanks, Brian. There's an actual discussion of the Velios tank here: http://www.914world.com/bbs2/index.php?sho...5&hl=velios Sorry, again, everyone for rushing to post w/o first using the search function. I'll take that collective (IMG:style_emoticons/default/slap.gif) now! |
number6 |
Updated question. Same vein as original but factoring in what I've found through a quick search.
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,197 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
OK, as it turns out, I do have a valid oil tank question! Excess oil would simply drain out (through my breather tank drain) and/or burn off? -duc And out of every nook & cranny it can force it's way out of. I had a Porsche mechanic over-fill my stock tank and the whole engine compartment was an oily mess by the time I got home. T.C. ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,733 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Just think of it as a protective coating TC!
Lo-Fi Version | Time is now: 20th June 2024 - 05:43 AM |
