my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09 |
jsayre914 |
Mar 3 2009, 04:52 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
take a look guys, by the way I did get her home the other night, and i beat the snow.
Attached image(s) |
jsayre914 |
Mar 3 2009, 04:54 PM
more
Attached image(s) |
jsayre914 |
Mar 3 2009, 04:56 PM
Attached image(s) |
jsayre914 |
Mar 3 2009, 04:57 PM
last ones
Attached image(s) |
jsayre914 |
Mar 3 2009, 04:58 PM
Zach said he would loan me a compression tester, i guess that is my next step.
thanks for looking joseph |
yeahmag |
Mar 3 2009, 06:51 PM
Advanced Member Group: Members Posts: 2,443 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Been a while since I had FI on the car. Could you tell if it was coming from one of the breather tubes for the heads? Any smoke out of the tail pipe while running? I can't imagine anything other than excessive blow by causing that - which the compression test should show you.
Jake Raby |
Mar 3 2009, 06:54 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Tons of blow by... Either the rings are shot or the exhaust valve guides are shot, or both..
type47 |
Mar 3 2009, 07:09 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Good thing a response I made didn't get posted..... I questioned the compression test.... My lack of skilz...
I would like to know about the "blow by" you (especially Jake) mention. What is it exactly and would it cause that much oil mess? (Just asking for my education). |
yeahmag |
Mar 3 2009, 07:21 PM
When combustion gases go flying past the rings they can only escape through the PCV and the head vents. The gases pick up oil and oil vapor(s) along the way giving you a nasty mess (as witnessed above).
Jake Raby |
Mar 3 2009, 07:28 PM
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice...
The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. |
Dr Evil |
Mar 3 2009, 07:54 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So, when are we going to rebuild your engine (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/idea.gif)
wertygrog |
Mar 3 2009, 08:06 PM
wertygrog Group: Members Posts: 429 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
My engine does the same thing when a hose falls off the head breathers or any other part of the pcv system. Check all your hoses and connections...sometimes they crack or loosen up down by the cylinder head.
VaccaRabite |
Mar 3 2009, 08:10 PM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Hey Joe,
I'm not in class this week. Next week I have Monday off, but it gets insane again for me right after that. If it is sucky outside, we can warm up your engine by running it in the garage with a hose hooked up to the exhaust pipe. If your valves have not been done in a while, I'll bring feeler gauges too. If it comes to it that you need to rebuild, all my resources are at your disposal. If you get good numbers, we can look and see if there is something else funky. I won't lie. I want to help you rebuild your engine. I've got all this crap now, and I want to use it. Zach |
championgt1 |
Mar 3 2009, 08:15 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No.
jsayre914 |
Mar 3 2009, 09:22 PM
Could you tell if it was coming from one of the breather tubes for the heads? the hose it is comming from goes into the threeway split thing front left side of the engine, from there i would guess it is coming from the head. QUOTE Any smoke out of the tail pipe while running? yes, espically from hard throtle when i let go of the pedal. |
jsayre914 |
Mar 3 2009, 09:24 PM
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice... The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. (IMG:style_emoticons/default/idea.gif) so does the engine still gotta come out if it is the valve guides? |
jsayre914 |
Mar 3 2009, 09:28 PM
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No. the car ran absolutly great, even with the smoke... it is/ was fast. i used a piece of silicon inside the double stack, but im not so sure it was perfectly tight, and from what im learning there is quite a bit of pressure in my case. |
r_towle |
Mar 3 2009, 09:33 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice... The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. (IMG:style_emoticons/default/idea.gif) so does the engine still gotta come out if it is the valve guides? Yup and it takes less than a hour to get it out. Rich |
jsayre914 |
anyone know where this came from??
Attached image(s) |
r_towle |
Mar 3 2009, 09:34 PM
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No. the car ran absolutly great, even with the smoke... it is/ was fast. i used a piece of silicon inside the double stack, but im not so sure it was perfectly tight, and from what im learning there is quite a bit of pressure in my case. From what I have experienced with lots of motors, not just type 4, is if you get smoke on the highway when you let off the gas pedal, its rings. Rich |
Lo-Fi Version | Time is now: 22nd December 2024 - 01:28 PM |
