car of the month... how do they do that |
dflesburg |
Mar 5 2009, 08:59 AM
Senior Member Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Over the years I have seen several cars with the rear fenders burped out a bit like the car of the month.
How is that done and how do you get both sides the same? |
sww914 |
Mar 5 2009, 10:06 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Adoman did a great thread on how he pushed his out. Sometimes they cut and add extra metal but usually not.
ConeDodger |
Mar 5 2009, 10:13 AM
Apex killer! Group: Members Posts: 23,860 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You can actually buy a tool to do it from body shop supply stores or do the shade tree method whis is to work it with a baseball bat or some other cylinder that can be put between the tire and inner fender. Do a search on rolling your fenders...
Given the car is a 914 and they are known to have funky dimensional control, I would use the distance between the tire and the outer fender as the measure for getting it the same. If you use the inner wall they could have been different measures before you start... |
PanelBilly |
Mar 5 2009, 10:22 AM
914 Guru Group: Members Posts: 5,865 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Making fenders match. That's funny. Well, you work the metal and then you measure and you do it again and again and again, and you invite your neighbor over for some advice and you drink a beer and you think about how it ought to work and you hope the metal doesn't fatigue before you get the shape and you weld in some more metal.
And you give up and hire someone else to do it and they make you hand over a larger amount of money than you want to spend and they do a reasonable job. Maybe not perfect, but since you are worn out, you go on to the next project. And the people who look at it , don't ever notice that its off by a fraction of an inch. Every time you look at it you see ever flaw. You should try it! Its fun and rewarding |
Lavanaut |
Mar 5 2009, 12:41 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
dflesburg |
Mar 5 2009, 01:22 PM
answer found: John Kelly school of fender flaring....
Lo-Fi Version | Time is now: 5th January 2025 - 12:22 AM |
