> Smog Pump Help Needed, Belt change
Derek Seymour
post Mar 11 2009, 09:01 PM
Does the belt attach to the fan to pump or the alternator to pump?
If on the fan are there two grooves on the cooling fan, one for the alternator belt and one for the smog pump?
Or is there supposed to be a secondary pulley coming off the alternator shaft... if so I seem to be missing that.
Thanks for ANY help!!!!!!
Cap'n Krusty
post Mar 11 2009, 09:31 PM
Cap'n Krusty
There's a secondary pulley assembly that comes off the crankshaft. It consists of a 3 point bracket and a pulley with a shaft that bolts to the fan hub through a rubber damper. NLA, but I have a couple of good used ones. The Cap'n
Derek Seymour
post Mar 11 2009, 09:35 PM
QUOTE(Cap'n Krusty @ Mar 11 2009, 08:31 PM) *
AWESOME!!!! Could I buy one off of you? Looks like we are 30 minutes away would you be available this weekend, I could drive down and pick it up?
THANKS!!!!
arvcube
post May 7 2009, 06:27 PM
could I get a pic of this assembly emailed to arvcube@aol.com or posted on this thread? do you still have any more of these?
thanks,
arvin
ejm
post May 7 2009, 07:27 PM
I can see the light at the end of the tunnel
I have a couple of these also.....
arvcube
post May 7 2009, 10:05 PM
QUOTE(ejm @ May 7 2009, 06:27 PM) *
thanks for the pic ejm. How much do you want for one shipped to 92064?
- Lo-Fi Version Time is now: 4th January 2025 - 08:01 PM
