RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
Here's the link to the article on Pelican:
http://www.pelicanparts.com/techarticles/9...tric_washer.htm The main question here is: Will the one out of a 944 work? P/N 477-953-902-01C-M100 Has anyone successfully used the 944 unit? Known differences? Edit: Rob (mojorisen) and I were discussing this for our cars. His is 74 mine is 76. |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Look here for Andys write up. i used the wire coming out of the steering column.
http://www.914world.com/bbs2/index.php?showtopic=13261 8) 2 options for the wiring: 8a) run 2 wires inside and mount a separate switch (push button style) either in the dash or the center console, and hook it up to 12V (through a fuse of your choice) 8b) if you have the intermittend wiper relay harness, you can also run the pump off that, just extend the brown/black wire (trigger from steering column) and use it as the 12V feed for the pump. this way, every time you pull the wiper lever towards you, you get the 4 run intermittend + fresh water! NOTE: the brown/black wire was NOT an option on early car, '72 and later, if i'm not mistaken ... |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
The main question here is: Will the one out of a 944 work? P/N 477-953-902-01C-M100 I followed the article and installed one in my last 914. I think I used a BMW washer pump I bought off eBay. Your FLAPS might even have a kit you could use the pump from. Nothing special about them really. |
RJMII |
The article called for one out of a 924; which is P/N ... uhh... I lost the P/N. it was from an early 924, though. The P/N listed is the later 924/944 model.
I'm thinking that I will use Andy and Chappy's ideas for mine and go off of the intermittent relay. I've got the parts to do it that way. =o) Rob's on his own, though. (IMG:style_emoticons/default/av-943.gif) |
iamchappy |
I used a universal electric pump from the auto parts store.
RJMII |
Chappy, was it an option, or on all the cars post 72?
Rob was saying that when he pulls back on his lever it just squirts and the wipers don't go back and forth. (I don't know why he couldn't ask this here (IMG:style_emoticons/default/poke.gif)) bad relay maybe? where's the relay? |
mojorisen914 |
Visit your local strip club ![]() ![]() ![]() Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains ![]() |
Dammit Jim (Bones McCoy vioce), when I pull back on the lever, nothing happens at all. (IMG:style_emoticons/default/poke.gif)
RJMII |
Dammit Jim (Bones McCoy vioce), when I pull back on the lever, nothing happens at all. (IMG:style_emoticons/default/poke.gif) So the relay then? Or in computer terms... PEBKAC. (problem exists between keyboard and chair) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:17 AM |
