StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
I just woke up my car from a long winters nap. Car fired right up and I let it warm up before I took her for a spin. I noticed before I put the car away for the winter that I was starting to experience some bucking when I realease the clutch in first gear. Well the bucking is still there, would this be a sign of a bad pressure plate or what would cause this problem. Will be pulling the motor soon to check on a few things since this motor is a new rebuild.
Shade Tree |
Member ![]() ![]() Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest ![]() |
Bad seals letting oil get on the flywheel....clutch chatter. Or it could be a broken front motor mount.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
(IMG:style_emoticons/default/agree.gif) Check for broken front motor mounts. Applying some pressure with a floor jack under the motor can tell you. If the motor moves a bunch relative to the bar, then your front mounts are gone.
Lo-Fi Version | Time is now: 26th June 2024 - 08:06 AM |
