Ground point? If so, for what? |
rjames |
May 14 2009, 07:28 PM
I'm made of metal Group: Members Posts: 4,110 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Should there be a ground wire attached here? Seems like I recall a thread stating all of the ground points in a 914, and behind the relay board on the firewall was one of them. Is that correct, and if so, which ground should be attached here?
Wait, I just had a 'duh' moment. Is this just a bolt that secures something inside the cabin? |
tracks914 |
May 14 2009, 07:37 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I think that's the back of the seat belt bolt. The ground is on the outside wall to the left in that picture.
rjames |
May 14 2009, 08:26 PM
I think that's the back of the seat belt bolt. The ground is on the outside wall to the left in that picture. Well then, I'm so glad I pulled back the firewall pad and ripped it a bit to get a better look at. (IMG:style_emoticons/default/headbang.gif) Now I'm off to see if there is indeed the ground on the outside wall and I'll try not to ruin anything else while I'm in there... |
EdwardBlume |
May 14 2009, 08:28 PM
(IMG:style_emoticons/default/av-943.gif) yeah, that's your seat belt. Let me know if you need another engine pad.
rymann |
May 14 2009, 09:04 PM
Newbie Group: Members Posts: 13 Joined: 22-March 09 From: so cal Member No.: 10,191 Region Association: None |
seatbelt is bolted to side pillar it looks like some one put that there for the seat pad that they prob broke the tab off of the seat pad and made that to hold the top of the pad
good luck |
EdwardBlume |
May 14 2009, 09:38 PM
seatbelt is bolted to side pillar it looks like some one put that there for the seat pad that they prob broke the tab off of the seat pad and made that to hold the top of the pad good luck That's where the top of the belt with the spring retractor attaches. It twists to function towards the side from there. |
rymann |
May 14 2009, 10:36 PM
yes u r right i have a 71 and a 75 the 75 has the retracter mount there the 71 has it down on the bottom by the seat
EdwardBlume |
May 15 2009, 12:09 AM
watsonrx13 |
May 15 2009, 05:42 AM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I think that's the back of the seat belt bolt. The ground is on the outside wall to the left in that picture. Here's a link to my website that shows the location of the grounding bolt. It's on the side of the fender, between the large circular impression and the (2) hoses and underneath the forward relay panel mounting bracket... BTW, this is a '74 MY... Hope this helps... -- Rob |
Lo-Fi Version | Time is now: 21st September 2024 - 07:03 PM |
