Back Pad mounting, early '70 six |
djm914-6 |
May 30 2009, 11:35 AM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
Can someone tell me what screws or bolts are used to mount the back pad to the firewall? I know it was mounted at some point but for the life of me I don't seem to have anything that fits anymore.
I assume these are to be machine screws as it looks like there is a nut behind the tin?? What size and shape do I need to buy? Thanks. Oh, there is a larger green and (IIRC) brown wire with female terminals in the tunnel by the interior light wires. Any idea what those are for? |
914Sixer |
May 31 2009, 06:55 AM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Wires are for the heated back window. They were built into the harness on the -6 but not on the -4. I will have to check the chrome phillips metal screw size.
djm914-6 |
May 31 2009, 11:59 AM
Thanks for the info. Let me know if you find that screw size so I can pick up a set. I figure I should be able to get something at Lowes if all else fails.
Lo-Fi Version | Time is now: 4th January 2025 - 10:00 PM |
