Front Sway Bar Mounting Plate |
jd74914 |
Jun 4 2009, 11:36 AM
Its alive Group: Members Posts: 4,818 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I have to pull my tank out to replace some lines and other stuff so now seems like the perfect time to put in a sway bar. I'd rather fab the plate than buy it (college student budget), and remember seeing a .dwg or picture with its dimensions. Does anyone have a copy of those or know the dimensions? The only one I'm really concerned about is the bolt spacing.
Thanks. (IMG:style_emoticons/default/smile.gif) |
SLITS |
Jun 4 2009, 11:46 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Bird Board has a template for drilling the holes that is printable off their site.
jd74914 |
Jun 4 2009, 11:52 AM
Cool. That's easy. Thanks.
Anyone know the bolt size? Edit:That should be on PET so its attainable, NM. |
McMark |
Jun 4 2009, 01:23 PM
Whatever bolt you want. But please, stick with metric/original and use 8mm x 1.25 bolts. (IMG:style_emoticons/default/wink.gif)
914werke |
Jun 5 2009, 10:07 AM
"I got blisters on me fingers" Group: Members Posts: 11,029 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
BTW the Factory didnt put anything inside to accomodate the anti-sway bar they spot welded a nut plate on the outside.
SirAndy |
Jun 5 2009, 11:19 AM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
BTW the Factory didnt put anything inside to accomodate the anti-sway bar they spot welded a nut plat on the outside. The factory also ran a skinny ass sway bar that didn't put much stress on the surrounding sheet metal. If you think you might decided to upgrade your sway bar in the future, do yourself a favor and weld in a backing plate ... (IMG:style_emoticons/default/stirthepot.gif) Andy |
Lo-Fi Version | Time is now: 26th December 2024 - 12:10 PM |
