Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I have a few of the outie tranz drain plugs and want to get some more, but all of the replacement parts are innies. WTF? In the PET many models with p/n 999 064 019 02 and 020 02 are outies so you can use a wrench on them and be happy. No 17mm allen needed. All of the suppliers I found had the same damn allen plugs assigned to the old part number. (IMG:style_emoticons/default/sad.gif) If I could find some I would buy a bunch and offer them on all of my rebuilds.
Here is a pic of what I want next to two of the old type that I had to drill out (fun and awesome) (IMG:style_emoticons/default/dry.gif) Attached thumbnail(s) ![]() |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
I'll take a couple! I've been trying on and off for a year to get mine out..no luck! Bill
Dr Evil |
So are you selling them?
banger |
Member ![]() ![]() Group: Members Posts: 354 Joined: 12-November 06 From: Santa Clarita Member No.: 7,205 Region Association: Southern California ![]() |
What is the thread size? You can get 20mm dia X 30mm bolts from mcmaster carr, which should work, and are easier to get...
Dr Evil |
The thread is NPT so it is tapered. The problem I am having with the standards is that they are soft and people keep tightening them down flush which is way to much.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If that is NPT, go to a plumbing supply house...there must be a real plumbing supply place near you...NOT home depot...
That is a standard gas fitting stopper. Rich |
Dr Evil |
Well, maybe not NPT, but a tapered fitting. Is there a metric version of NPT? I will check the good hardware store tomorrow (IMG:style_emoticons/default/smile.gif)
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Got one of those metric thread checkers?
Got one with my Sears tap and die set and have used it a lot. |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
It is M24 x 1.5 tapered.
Dr Evil |
Thanks, James (IMG:style_emoticons/default/smile.gif) No luck at the hardware store (IMG:style_emoticons/default/sad.gif)
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Here is 3 shots of a NOS drain plug. I have no idea where I got it from. I will ship it to you if you need it to locate others with.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
PM sent
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
Mike,
if you don't find something give these guys a call. http://www.readingfoundry.com/index.html If not the foundry try these guys http://www.clarkindustrialsupply.com/ |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Have you tryed welding a suitable bolt to the plug to remove it vs drilling and easy outting ??
The heat should help break it loose some . Jaxdream |
Dr Evil |
I dont weld, the HOA frowns on it (IMG:style_emoticons/default/wink.gif)
I MAP gassed the plugs for a while and they did not budge. Drilling them out was the best, safest, quickest bet. I hate doing it, but it works. |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
If finding the correct " outie " plug is impossible what about having " innies " welded with a short section of allen wrench in them? That would turn them into outies correct? Have the section of allen wrench protrude aprox. 3/4 - 1 inch so you can put a socket on it?
Dr Evil |
Time + resources + $$ = Not on a scale of more than 2 (IMG:style_emoticons/default/wink.gif)
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
It is M24 x 1.5 tapered. i just typed what he said into my browser and found this, if that helps http://efc-capsandplugs.com/productspec.asp?56,136,04A299 (IMG:style_emoticons/default/driving.gif) |
Katmanken |
Yowzers.....
Are we getting close???? http://seawaybolt.com/din.html Hmmm... that's frickin weird... I can't post an internet linky like I used to.... "you must enter a URL before posting a linky".... Must be the new XP and Explorer 8..... |
Dr Evil |
Thats it! I wonder how much or how big an order?
Lo-Fi Version | Time is now: 20th June 2024 - 06:17 AM |
