nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
so after 2 weeks of pretending that i don't own a 914, i am goin to try to get it running again. finally got new valve adjustment screws (fed-ex lost em for a while). i need to know how much to torque down the nuts on the h.e's ( if i strip a stud i will kill myself)
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,002 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
so after 2 weeks of pretending that i don't own a 914, i am goin to try to get it running again. finally got new valve adjustment screws (fed-ex lost em for a while). i need to know how much to torque down the nuts on the h.e's ( if i strip a stud i will kill myself) *EDIT* I apparently had the numbers wrong, see below. |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Make sure you either anneal, or use new copper exhaust gaskets.
Otherwise, the torquing will be for naught. BTW, where do you keep your 914 in NYC? It has been a long time since I've seen a teener running around Manhattan. |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I don't believe any torque spec is in the Haynes manual. I thought that the exhaust studs were torqued to 14 or 14.5 ft/lbs (because they're going into aluminum and the copper nuts that hold the HEs on were 12 ft/lbs.
Someone please render a decision. |
nycchef |
Make sure you either anneal, or use new copper exhaust gaskets. Otherwise, the torquing will be for naught. BTW, where do you keep your 914 in NYC? It has been a long time since I've seen a teener running around Manhattan. i'm in bklyn. if you see a "running" 914. it 's probably not mine (IMG:style_emoticons/default/av-943.gif) |
Cupomeat |
Cool, I was in Park Slope for a few years but my teener never saw the mean streets (kept in storage, upstate).
Loved P. Slope and Prospect Park. I am about 16 mi west of the city, let me know if I can help out. I've been through most everything on 914s, just never rebuilt the transmission. |
nycchef |
Cool, I was in Park Slope for a few years but my teener never saw the mean streets (kept in storage, upstate). Loved P. Slope and Prospect Park. I am about 16 mi west of the city, let me know if I can help out. I've been through most everything on 914s, just never rebuilt the transmission. probably will, just put the rocker assembly back in with new screw, the h.e'. and the flapper box and it's running again. gonna pick up a new carb linkage na dtry to put together a wrenching party, maybe with ray mital in n.j. will let you know. if you come to manhattan, i have a southwestern/mexican restaurant on the upper east side, 914 owners eat free rich |
Cupomeat |
I am in Manhattan everyday, and I love Mexican/southwestern food.
Let me know when the wrenching party is, I'll try to be there, or I can offer my garage if that works for you all. |
jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
I don't believe any torque spec is in the Haynes manual. I thought that the exhaust studs were torqued to 14 or 14.5 ft/lbs (because they're going into aluminum and the copper nuts that hold the HEs on were 12 ft/lbs. Someone please render a decision. (IMG:style_emoticons/default/agree.gif) That's right. M8 into aluminum is only 14 ft-lbs. Remember that though the nut is steel (copper-plated only!) the torque is distributed down the length of the stud, and the other end goes into aluminum. I have the Bentley manual for VW T4, and it states 14 ft-lbs also, IIRC. Interestingly, M9 into aluminum is about 17 ft-lbs, which is about the same as M8 into steel, so if you're running 9mm/8mm step studs, both ends can handle 17 ft-lbs, and you can go a but tighter. Someone correct me if I'm wrong, but didn't the 1.8 came from the factory with the 9mm/8mm step studs. My theory is that this was part of the reason. Similarly, the rocker studs are 8mm/7mm step studs, with the big end going into the aluminum head- same reason? Who knows! |
nycchef |
I don't believe any torque spec is in the Haynes manual. I thought that the exhaust studs were torqued to 14 or 14.5 ft/lbs (because they're going into aluminum and the copper nuts that hold the HEs on were 12 ft/lbs. Someone please render a decision. (IMG:style_emoticons/default/agree.gif) That's right. M8 into aluminum is only 14 ft-lbs. Remember that though the nut is steel (copper-plated only!) the torque is distributed down the length of the stud, and the other end goes into aluminum. I have the Bentley manual for VW T4, and it states 14 ft-lbs also, IIRC. Interestingly, M9 into aluminum is about 17 ft-lbs, which is about the same as M8 into steel, so if you're running 9mm/8mm step studs, both ends can handle 17 ft-lbs, and you can go a but tighter. Someone correct me if I'm wrong, but didn't the 1.8 came from the factory with the 9mm/8mm step studs. My theory is that this was part of the reason. Similarly, the rocker studs are 8mm/7mm step studs, with the big end going into the aluminum head- same reason? Who knows! i torqued them down at about 15 lbs (tough to be accurate stuffed under the car), ran it for an hour nothing flew out of the valve train. just might get it off the jack stands this week (IMG:style_emoticons/default/driving-girl.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
When is the wrenching party? (IMG:style_emoticons/default/smile.gif)
nycchef |
wish i could tell you. problem getting time at movietime. my garage is tiny, and i still need to put in the shifter console before i can get mobile i/ll see what i can do RAY whats up with you !!!! |
Dr Evil |
Ya, I need your console back. Its an exchange thing, ya dig?
nycchef |
Dr Evil |
The bill is $50 (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 1st July 2024 - 01:06 PM |
