Setting timing, How to do it right? |
VaccaRabite |
Aug 5 2009, 05:14 PM
En Garde! Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Cam is a Raby 9530
Engine is a 2056 Deckheight is .040 Dizzy is a mallory, and I am using a bosch blue coil. induction is through dual IDF44 At what engine RPM should I set my timing, and how much advance do I want to use? I know I don't want to do it at idle, but I don't know at what RPM I should target. Thanks! Zach |
JoeSharp |
Aug 5 2009, 05:22 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
You want full advance Zack. I do it at about 3500 RPM and 32* just to be sure.
aircooledtechguy |
Aug 5 2009, 05:46 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
For years the standard with a Mallory w/ gray/gray springs has been 12* @ idle and 28*@ 3K. Jake will probably chime in with different numbers now that I've posted those. (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Aug 5 2009, 05:52 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Zach, 3k rpms at 28 degrees is safe...any more and you may end to advanced.
You dont want to have detonation. At 3k-3500 the distributor (any distributor) is at full advance. This is the best place to know for sure what the timing will be at full advance. Rich |
VaccaRabite |
Aug 5 2009, 06:45 PM
Rock.
Thanks guys. Zach |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:40 PM |
