Trying to decide whether or not to rebuild, ? |
buhs914 |
Aug 8 2009, 09:08 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
Well i have my engine out and mostly stripped so i can clean the gunk off from the oil leak.. while i have it out should i rebuild it? i have no idea when it had it done last.. i don't believe that in needs to be done but who knows..
r_towle |
Aug 8 2009, 09:27 PM
Custom Member Group: Members Posts: 24,661 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Clean it, fix the leak..put it back together, put it back in, Drive it like you stole it...
then in late november pull the motor and rebuild it. Rich |
type47 |
Aug 8 2009, 09:30 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
or buy a motor to rebuild as you drive it like you stole it.... (IMG:style_emoticons/default/biggrin.gif)
then when you're ready, swap it out in a weekend... if it runs, I don't see the need to rebuild unless compression or leakdown tests show definite faults.. |
3d914 |
Aug 9 2009, 09:46 AM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I agree.
914's tend to spend too much time in the garage once you start the process. So get out there now while you can! Enjoy! |
Lo-Fi Version | Time is now: 26th December 2024 - 09:15 PM |
