ppickerell |
914 addicted ![]() ![]() ![]() Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 ![]() |
ran across this on C-list
email this posting to a friend Porsche 2.7S Complete Motor -------------------------------------------------------------------------------- Reply to: anon-25489837@craigslist.org Date: 2004-03-01, 4:05PM PST Motor is complete including the fuel injection, distributor, flywheel, wiring harness. It ran until one cam went bad with a flat spot. The cam has been replaced and the motor is on a stand now. I would like $1,200 obo, or interesting trades. Exhaust and oil cooler are not included, thanks for looking it's NOT ok to contact this poster with services or other commercial interests 25489837 -------------------------------------------------------------------------------- Copyright © 2004 craigslist terms of use privacy policy feedback forum |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Went looking on Clist and found this:
Reply to: brettvining@yahoo.com Date: 2004-03-02, 3:28PM PST 73 914se completely restored to showroom quality. Green/black. $30,000 I have all receipts. This car is a must see! |
ppickerell |
Dave,
What heading did you find that under? |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Stay away from the thermal reactor 2.7S engines. Huge issue with heat warping everything. 1200$ is a decent price... but approach with caution.
B |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
How the hell do you eat a cam lobe on a Six? Only way I can think of is clogged oil passages--which means Bad News for the rest of the motor.... (IMG:style_emoticons/default/sad.gif)
--DD |
Brad Roberts |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
The 2.7 sixes are reliable as long as they're not run with the stock thermal reactors. If it was just pulled from a '75-'77 911, however, it's a core engine that almost certainly needs a rebuild. The thermal reactors were perhaps the dumbest idea Porsche ever came up with. It sounds like this engine had some serious problems, and it was only patched up.
914ghost |
BOB ![]() ![]() Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 ![]() |
N'kay, someone wanna tell about the thermal reactors?
I have a 2.7 in the garage- going to a new home soon- but I like to know all I can. I've worked on a few /6's and know my way around stuff- but without sounding stupid (too late?) what and where are they located? The 2.7 I have had many upgrades and was well maintained and running when removed. TIA Bob O |
Dave_Darling |
CA-spec 75-77 911s. Possibly 76-77 US-spec? Not sure on that.
They're part of the exhaust. They heat up the exhaust gases a lot to finish burning off any leftover hydrocarbons. Sometimes, at night, you can actually see them glowing a little underneath the car. They generate enough heat that they tend to cook the engines attached to them.... --DD |
lapuwali |
I think they were used on all US '75-'77, not just CA. Federal regs got a LOT tighter in '75, and CA switched to tighter still standards that same year. If you look, you'll notice that very many cars suddenly had catalytic convertors in '75, like the 914 itself.
Thermal reactors were what a very few manufacturers chose to use instead of catalytic convertors. None of them used them for long, partly because they didn't work as well as catalytic convertors at removing emissions, and mostly because they generated such incredible underhood temps. Big cast-iron things designed to get hot and stay hot, like 900-1100dF hot. The idea was, where early catalytic convertors use a platinum catalyst to promote reaction of HC and CO with O2 to create H20 and CO2, the thermal reactors would do the same thing, but with heat alone. Why a bunch of German engineers ever thought it was a good idea to take an air-cooled engine already stretched to its limit and place a 900dF cast-iron block next to it, I don't know. The '74 2.7s worked fine, as none of them had thermal reactors. The later ones expired with pulled studs, worn-out guides, etc in such a short time that Porsche got a very black eye with many US owners. To make amends, they stuffed the Turbo case in the '78 3.0SC along with catalytic convertors and very mild tuning, and as a result, the 3.0 is one of the most durable 911 engines of the entire series. If you ever wondered why mid-70s 911s are cheaper than earlier or later cars, now you know. If you're just looking for a core to rebuild, the 2.7 is generally cheaper than others, and costs about the same to rebuild, so they're a good deal as long as you're going to fit them into a car that doesn't require you to run the stock thermal reactors to meet local emissions regs. If you're looking for a Six you just want to plonk into a 914, I'd use a 2.2 or a 2.4. They're much lighter than the 3.0 (magnesium v. aluminum block), and generate plenty of power for the light 914, and they're going to be cheaper than the 3.0 or 3.2 engines, to boot. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Not cheep for free.
Ask yourself: "Where did the lobe (s) go?" |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(Dave_Darling @ Mar 10 2004, 03:26 PM) How the hell do you eat a cam lobe on a Six? Only way I can think of is clogged oil passages ... in the case of the 2,0 engine in my yellow car, i was told an oil line failed and wiped the cam before all 9 qt got pumped out. i just replaced a line on my 'E' and i don't think it was far from that condition at the time - and neither of those ran nearly as hot as a 2,7. as a result, i have a nice 'E'-cammed 2,0 /6 - was the cheap way out 'cause the shop was uprating a 911E to 'S' and they had these parts in a box... |
ArtechnikA |
QUOTE(lapuwali @ Mar 10 2004, 06:24 PM) Thermal reactors were what a very few manufacturers chose to use instead of catalytic convertors. None of them used them for long, partly because they didn't work as well as catalytic convertors at removing emissions, and mostly because they generated such incredible underhood temps. Big cast-iron things designed to get hot and stay hot, like 900-1100dF hot. The idea was, where early catalytic convertors use a platinum catalyst to promote reaction of HC and CO with O2 to create H20 and CO2, the thermal reactors would do the same thing, but with heat alone. Why a bunch of German engineers ever thought it was a good idea to take an air-cooled engine already stretched to its limit and place a 900dF cast-iron block next to it, I don't know. The Big Difference: (lots of young guys don't remember this ...) the thermal reactor cars were still LEADED GAS cars. unleaded gas was something of a novelty in '74 and not in widespread availability until '76. Porsche hadn't figured out how to make the whole catalyst engine package -- from fuel management to packaging the catalysts - when the new regs happened and they did what they had to in order to stay in the market. Porsche never thought it was a good idea, but it was a business decision to sell cars they could build rather than withdraw from the market for 2 years. |
lapuwali |
Perhaps this was true in PA, but not in CA. All but a very small handful of cars sold in CA in '75 had catalytic convertors. Unleaded gas had to be widely available by that time.
Figuring out the engine management wasn't really Porsche's doing. Bosch was doing all of that work. The '74-'77 cars all used CIS, as did the '78-'82 catalytic convertor cars. The difference was the later systems used an O2 sensor, where the earlier systems were open loop. The earliest catalysts available didn't require a fully closed loop system (and suffered for it, dying relatively early). Given the 914 never used thermal reactors, but used catalysts from the start (in 1975, with L-Jet rather than K-Jet/CIS), the knowledge of how to use them was readily available to Porsche from both VW and Bosch. Hindsight is 20/20, but given the public reaction, and given Porsche's reaction to that (the SC), I'd say that they didn't realize at the time how bad the problem was going to be, and regretted the decision. Company politics was no doubt involved heavily. This was also the period the 928 and 924 were being introduced, and factions within Porsche were seriously trying to kill the air-cooled rear-engined cars completely. They certainly didn't realize at the time that it would be another 20 years before that happened. |
Dave_Darling |
QUOTE(ArtechnikA @ Mar 11 2004, 06:31 AM) QUOTE(Dave_Darling @ Mar 10 2004, 03:26 PM) How the hell do you eat a cam lobe on a Six? Only way I can think of is clogged oil passages ... in the case of the 2,0 engine in my yellow car, i was told an oil line failed and wiped the cam before all 9 qt got pumped out. Oh... I didn't think of that. I was thinking only of a single-lobe failure. Regardless, I think that engine is a core. Maybe a running core, but still just a core. --DD |
krk |
Senior Member ![]() ![]() ![]() Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 ![]() |
Of course, we need a Pic. This is a thermal reactor off a 76 turbo.
The inside of the barrel part is supposed to be filled with some sort of system of ceramic plates -- which heat up and do something passable with the exhaust that comes out to make the smog folks dance in their booties -- but imagine having one of these suckers placed up nice an tight below the cylinders generating massive heat .... Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 03:13 AM |
