andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Has anyone (Brad?) ever cut a trailing arm apart? I'm wondering if there are any additional structural elements inside, or are they basically two U sections welded together to form a rectangular cross section, and hollow inside. I'm not talking about the pivot point/bushing or the bearing/hub areas, but the section between them.
Thanks, Andy |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
it's built up sorta like a corragated card board box...it is not 100% hollow inside
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,709 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
I have a bent one if someone wants to cut it open and see!!
Jeff |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Nothing is inside a trailing arm.
I cut this one open with my plasma cutter yesterday to show you. This one had the box reinforcement on it, thus the extra thickness on one side. Attached image(s) ![]() |
agentblr |
Member ![]() ![]() Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 ![]() |
I think my rear arm have corn flakes inside them? at least it sounds like when you shake them,this is bad (IMG:style_emoticons/default/unsure.gif)
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
Uh Chris, was there something wrong with that trailing arm? Cutting up a reinforced trailing arm for demonstration purposes only would be mighty big of you.
Andy was right, there is something inside, rust. |
majkos |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains ![]() |
(IMG:style_emoticons/default/agree.gif) Why the chop? (IMG:style_emoticons/default/confused24.gif)
"Don't worry be Happy!" (IMG:style_emoticons/default/beer3.gif) It's St Patty day! |
andys |
QUOTE(Racer Chris @ Mar 17 2004, 08:01 AM) Nothing is inside a trailing arm. I cut this one open with my plasma cutter yesterday to show you. This one had the box reinforcement on it, thus the extra thickness on one side. Racer Chris, Thanks for the fantastic pic....just what I suspected, a simple rectangular section....no big deal. I know I'm pushing it, but what is the stock material (wall) thickness? Andy |
Mueller |
damn...then what the heck was I thinking of then???? I must be thinking (or not) of another car or part...thanks for making a liar out me (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/blink.gif)
SirAndy |
QUOTE(Mueller @ Mar 17 2004, 09:59 AM) damn...then what the heck was I thinking of then???? I must be thinking (or not) of another car or part...thanks for making a liar out me (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/blink.gif) you were thinking of the later model long in the area under the battery tray. the later models have "rippled" reinforcements in there ... Andy |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE rust? Looks like Andy had the answer all along... |
ChrisFoley |
Actually that rust color is plasma cutting residue,which probably will wipe off.
The trailing arm was involved in a high speed impact and had no further usefulness on a car - perfect for an autopsy. (IMG:style_emoticons/default/laugh.gif) I can check the wall thickness today. |
ChrisFoley |
I measured the metal thickness at .080" or 2mm.
andys |
Chris,
A BIG THANKS!!! Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 02:49 PM |
