3.2 flywheel to 901 tranny, 911 3.2 install |
mdan |
Sep 30 2009, 12:57 PM
Newbie Group: Members Posts: 13 Joined: 24-May 09 From: florida Member No.: 10,397 Region Association: None |
will the stock 3.2 flywheel work on my 901 tranny? if not, what flywheel do I need? anyone have a used one for sale? I know pelican has a parts list, but I find this forum much more informative, fyi's, do's dont's etc. etc. also, the 915 tranny should bolt up? how do I use the shift mechanism, take the one out of the 911? flip the ring and pinion gear too?
thanks, Mike 72 2.0 going 3.2 soon. |
Justinp71 |
Sep 30 2009, 01:38 PM
Senior Member Group: Members Posts: 1,606 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
The flywheel should work, you just have to call the nice guys at kennedy engineering and get there special flywheel, pressure plate and starter ring to mate the two together. And I guess you have to cut a notch in the 901 trans for the flywheel sensor. I'm sure some motronic guys will post, my background comes from mating a 3.0 and a 901.
SirAndy |
Sep 30 2009, 02:12 PM
Resident German Group: Admin Posts: 41,957 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have a stock 993 flywheel (sans a few pounds) on my 3.6L and i used a kennedy stage-2 clutch and pressure plate and a ring-gear adapter to mate it all to my stock 901.
As mentioned above, i had to notch the 901 for the sensor. Works quite well ... (IMG:style_emoticons/default/driving.gif) Andy |
SirAndy |
Sep 30 2009, 02:13 PM
736conver |
Sep 30 2009, 04:54 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Heres the cut I made on the 901 for the 3.2 sensors. I called PMS for the whole clutch setup.
attachmentid=191865] Attached image(s) |
Eddie914 |
Sep 30 2009, 06:54 PM
Unregistered |
I have nearly the same setup with my 3.2 engine and 901 transaxle combination.
Since the 3.2 engine in my teener uses Weber carbs, no notching of the transaxle was required. Eddie |
Lo-Fi Version | Time is now: 5th January 2025 - 01:30 AM |
