Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Sorry guys, I appreciate your help, but I want to be sure that the fuchs I have been offered are right for my narrow bodied 914.
They are 16 x 6 and I have asked for the seller to send me the part numbers, fo r which I have received the following reply... QUOTE 911 361.020 [43]. And 911 362.113. There are two wheels with the first part number and two wheels with the second part number on them. All the wheels have as10.62 on them. I'm pretty sure the offset is et36 Would these be good for me to spend my $$$ on?? (IMG:style_emoticons/default/biggrin.gif) |
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Die, Fuchs threads, die!!! (IMG:style_emoticons/default/fighting19.gif)
Eric Read (IMG:style_emoticons/default/lol-2.gif) |
Rod |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
6x16
36 mm 911.362.113.00 (late) 911.361.020.43 (early) I dont know the diff on the sixes , But on the sevens thearly and late have a different shape triangle window between the spokes. One being square on the rim side and the other curved . Get pictures of- each.- |
ericread |
Rod |
(IMG:style_emoticons/default/biggrin.gif) don't be silly I know you were (IMG:style_emoticons/default/wink.gif) |
Rod |
6x16 36 mm 911.362.113.00 (late) 911.361.020.43 (early) I dont know the diff on the sixes , But on the sevens thearly and late have a different shape triangle window between the spokes. One being square on the rim side and the other curved . Get pictures of- each.- Thanks for your help - here is a picture of them all Attached image(s) ![]() |
sixnotfour |
QUOTE Sorry Rod... Just kiddin around. YEAY Fuchs Thread!!! Eric http://www.wheel-whores.com/forum/viewforum.php?f=4 |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I think Jeff might have mis-read
on the 16's, I don't think there is an earyl/late, heart issue your good 16 x6's fit well probably 16x7s would fit with a narrow tire.. but the 6's are really safe your good to go! brant |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
I think Jeff might have mis-read on the 16's, I don't think there is an earyl/late, heart issue your good 16 x6's fit well probably 16x7s would fit with a narrow tire.. but the 6's are really safe your good to go! brant I'm running 16x7's on all four corners with 205-60's. slight rubbage on the rears because I need stiffer springs and adjustable perches. Cornering hard takes the tire up into the wheel well too far. |
RJMII |
Rod, if you're getting a good deal, jump on them before someone else does.
Rod |
I think Jeff might have mis-read on the 16's, I don't think there is an earyl/late, heart issue your good 16 x6's fit well probably 16x7s would fit with a narrow tire.. but the 6's are really safe your good to go! brant I'm running 16x7's on all four corners with 205-60's. slight rubbage on the rears because I need stiffer springs and adjustable perches. Cornering hard takes the tire up into the wheel well too far. With all of my Fuching about recently I have come to the conclusion that 50 series tyres are best for a 16" wheel ( I have 60 profiles on my 15" 4 bolts, so a lower profile on the larger wheel should be correct? ) |
RJMII |
Tire diameter = ((((width * aspect ratio)/10)/25.4)x2) + wheel diameter
there's the math. =o) |
Rod |
Rod, if you're getting a good deal, jump on them before someone else does. Will do (IMG:style_emoticons/default/biggrin.gif) I'll be back with a conversion thread soon... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/shades.gif) |
RJMII |
Rod, if you're getting a good deal, jump on them before someone else does. Will do (IMG:style_emoticons/default/biggrin.gif) I'll be back with a conversion thread soon... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/shades.gif) awesome! Your threads are usually a pretty good read. |
sixnotfour |
QUOTE I think Jeff might have mis-read on the 16's, I don't think there is an earyl/late, heart issue There is a early and late PN and on the 16x7's the base of the heart early curved and late straight. |
brant |
QUOTE I think Jeff might have mis-read on the 16's, I don't think there is an earyl/late, heart issue There is a early and late PN and on the sevens the base of the heart early curved and late straight. I didn't realize there was an early late in 16inch diameter I learn something new all the time! |
Rod |
QUOTE I think Jeff might have mis-read on the 16's, I don't think there is an earyl/late, heart issue There is a early and late PN and on the 16x7's the base of the heart early curved and late straight. So what are the differences between the four wheels, bar the part number? (IMG:style_emoticons/default/pray.gif) |
sixnotfour |
I found some documentation, All mine are early.pre 85 The 7's definately have a different shape heart.
http://forums.pelicanparts.com/porsche-911...variations.html Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 05:31 AM |
