Headlight "popup" doesn't |
Wardsweb |
Oct 3 2009, 10:23 PM
Member Group: Members Posts: 60 Joined: 8-September 08 From: San Antonio, TX Member No.: 9,527 Region Association: None |
The passengere side works fine. The driver side would not come up. I replaced the relay but it still won't come up. If I manually dial the light up, it goes down when I turn the key on. Does the mechanism have an internal limit switch?
VaccaRabite |
Oct 4 2009, 08:50 AM
En Garde! Group: Admin Posts: 13,629 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Same thing happened with mine.
Try a known good relay. |
Wardsweb |
Oct 4 2009, 12:47 PM
Drums66 |
Oct 4 2009, 01:47 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Try cleaning the individual grounds on each light?? (IMG:style_emoticons/default/idea.gif)
and check connection's. |
ClayPerrine |
Oct 4 2009, 05:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,965 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If the headlight goes back down when you manually raise it, then the motor and relay are fine. It sounds like the headlight switch is not sending a signal to the motor. Check where the motor connects to the wiring harness and see if one of the wires is coming unplugged.
Check out this thread.... How Your Headlights Work.. It gives a step by step explanation of how they go up and down. |
Lo-Fi Version | Time is now: 4th January 2025 - 11:10 PM |
