5 Pages V  1 2 3 > »
> suby turbo , the epic, resurrection
d914
post Oct 4 2009, 02:51 PM
been working on my project for awhile now,, read a long time!!!!..latest update..she's not naked any longer...2 years of bare metal and now I started spraying...... First time.. I'm handling the primer on my own.. (IMG:style_emoticons/default/wacko.gif)
Bigkat is traveling for work or some lame excuse!! (IMG:style_emoticons/default/beer.gif)
He will be handling the final hot rod black..
acid etch primer and the gray primer
d914
post Oct 4 2009, 02:54 PM
flares will have welting and be riveted on.. again fimal color, hotrod black..
d914
post Oct 4 2009, 02:56 PM
seats,,,ultra shield rally
d914
post Oct 4 2009, 03:02 PM
trunks, bottom and engine bay undercoated..
nomore9one4
post Oct 4 2009, 03:04 PM
Member of the Eastcoast Thread Killers Club
Nice project Greg! Are those the wider GT flares? Do you remember where you bought them? They look like a nice fit. Did you get the rocker covers to match? Can't wait to see it with paint. (IMG:style_emoticons/default/smile.gif)
d914
post Oct 4 2009, 03:16 PM
yes normal are 7 and 9,, these are 9 and 12..various sources including AA for the rockers,, I believe they are AIR..
turbo suby with the suby 5 speed for a little punch..
nomore9one4
post Oct 4 2009, 03:49 PM
QUOTE(d914 @ Oct 4 2009, 02:16 PM) *
Very nice choices! Thanks for the info. I will sit back and wait for the paint. (IMG:style_emoticons/default/driving.gif)
d914
post Oct 4 2009, 05:47 PM
for old time sake...the engine..
d914
post Oct 4 2009, 07:02 PM
a little mock up to keep me going..
pktzygt
post Oct 4 2009, 07:35 PM
For a while it was looking like you were going to keep sanding the rust and run out of metal before you got some primer on there.
As usual the suby guys are inspiring me to get mine put back together.
When I get mine done, I'm going to have to check yours out. I'm in your neck of the woods every so often.
ghuff
post Oct 4 2009, 07:37 PM
This is certainly not what I expected down here.
What is that shifter setup? That looks delightfully better than the factory piece.
d914
post Oct 4 2009, 07:39 PM
Im using the suby tranny with a honda cable shifter from an accord..
quadracerx
post Oct 5 2009, 06:02 PM
Excellent job.....Keep up the good work....Im trying to find the wider steel flares like you have? Cant seem to locate them.....Tried Auto Atlanta and the Pelican but cant seem to locate them....Can you help? They are actually for a friend....but ill need a set once business picks up...... (IMG:style_emoticons/default/aktion035.gif)
Thanks....this board is the best....
Steve
carr914
post Oct 5 2009, 06:15 PM
Racer from Birth
I don't think you will find those wider flares in steel. The factory steel flares were narrower and the wide ones have been made in F/G by aftermarket companies
T.C.
d914
post Oct 5 2009, 06:31 PM
mind are fg...tried to convince the son to go steel flares to no avail... You can get 9 in rims and 255's on the small flares...That will handle quite a bit of power..
d914
post Oct 5 2009, 06:35 PM
QUOTE(pktzygt @ Oct 4 2009, 09:35 PM) *
I did get yelled at for polishing the car!!! It was tuff pulling the trigger to put paint on the car...So long getting to bare metal....I played with the idea of just clear coating the car!! (IMG:style_emoticons/default/drunk.gif)
d914
post Oct 18 2009, 08:06 PM
primed, sanded, bondo'd, trial fit the rockers, primed and I'll probably sand some more...I think Im slowly getting this body work thing..
The rockers are close.. I need to trim a little more metal and a second pair of hands would help with final placement of the flares..
d914
post Dec 6 2009, 07:58 PM
ok long time and no update, I finisged body work, did final mock up on flares and drilled likea thousand holes!! riveting on.. and broke out the paint gun unsupervised!!!!...
I know I have a couple fixes on the fares and Im sure I do on the car since Im verically challegned!! They will just have t wait until tomorrow!!
Gint
post Dec 6 2009, 08:42 PM
Mike Ginter
That's cool... (IMG:style_emoticons/default/smilie_pokal.gif)
d914
post Dec 7 2009, 10:10 AM
definitly some touch up do,,daylight is not your friend!!!! Not too bad for my first attempt.. Mainly the flares need some follow up.. Here is some shots with the flares on with a cleco..
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 19th April 2025 - 01:59 PM
