Back PAD Compresed Carboard Restoration, Has anyone done this. |
xperu |
Oct 10 2009, 02:59 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Just looking for advice and maybe some pictures of restoration of backpad. Thanks Mike
zonedoubt |
Oct 10 2009, 03:21 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
I had to fix mine in a few spots where the pressboard was cracked. I used some thick cardboard as a patch (inside of binder covers), wood glue, and some clamps. Turned out not bad. You don't see it anyways. (IMG:style_emoticons/default/smile.gif)
benalishhero |
Oct 10 2009, 03:47 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
I had to fix mine in a few spots where the pressboard was cracked. I used some thick cardboard as a patch (inside of binder covers), wood glue, and some clamps. Turned out not bad. You don't see it anyways. (IMG:style_emoticons/default/smile.gif) I used the same technique with 2-part epoxy. I was able to straighten the water damaged lower edge and reattatch the vinyl at the same time. As Zone already stated, you don't see it anyway. |
Joe Owensby |
Oct 11 2009, 06:45 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I straightened mine out, added additional cardboard where it had disentegrated. I then put a layer of fiberglass on both sides, overlapping the old and the new. Then covered it up with new backpad material.
xperu |
Oct 12 2009, 05:49 AM
I straightened mine out, added additional cardboard where it had disentegrated. I then put a layer of fiberglass on both sides, overlapping the old and the new. Then covered it up with new backpad material. Thanks guys, I will use one of these options, while I'm putting the last trim peices together and finishing the interior, this is the last repair job. Thanks Mike |
johannes |
Oct 12 2009, 06:06 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
If you watch the classic threads you will see my door paner restoration thread. I restored the cardboard panel with white wood glue. You can also change the shape using a steam iron. http://www.914world.com/bbs2/index.php?showtopic=54608
morph |
Oct 12 2009, 09:17 AM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
We used to restore factory ones with fiberglass or epoxy.To flatten a area that is warped use 2x4s,or 6 with a release agent on them (clear shipping tape on the board so it wont stick to your back pad) and clamps.
james |
IronHillRestorations |
Oct 12 2009, 11:15 AM
I. I. R. C. Group: Members Posts: 6,793 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I use wax paper as a "release agent". You can also spread your fg mat with resin on a piece of wax paper and then apply it to whatever you are 'glassing.
Lo-Fi Version | Time is now: 4th January 2025 - 07:16 PM |
