> Need An Oil Breather Suggestion
kenshapiro2002
post Oct 10 2009, 06:38 PM
My oil breather hose just dead ends in my cooling "well". What a decent, affordable (like $50 or less) breather box that I can just vent into the atmosphere of the engine bay, pulling off the oil and not throwing it into my engine?
3 Pages V  1 2 3 >
Replies(1 - 19)
ChrisFoley
post Oct 10 2009, 08:12 PM
I am Tangerine Racing
QUOTE(kenshapiro2002 @ Oct 10 2009, 07:38 PM) *
(IMG:style_emoticons/default/stirthepot.gif)
Why spend any money at all? Next time you change the oil just save one bottle to route the hose into. (IMG:style_emoticons/default/headbang.gif)
(yes, I am being sarcastic)
tat2dphreak
post Oct 10 2009, 08:47 PM
stoya, stoya, stoya
you can get little empi breathers for not much, look at vw places. I'll see if I have a pic of mine...
tat2dphreak
post Oct 10 2009, 08:51 PM
stoya, stoya, stoya
here's the best pic I could find, I have the head venst and the vent for the oil breather going into it, on the firewall(though I will probably move it to the back wall of the engine bay)
here's a similar one:
http://www.vwparts.net/mm5/merchant.mvc?Sc...amp;range_high=
kenshapiro2002
post Oct 10 2009, 09:30 PM
Why would you want to move it to the back wall?
By head vents, are you talking about vented valve covers?
QUOTE(tat2dphreak @ Oct 10 2009, 10:51 PM) *
ChrisFoley
post Oct 10 2009, 11:30 PM
QUOTE(kenshapiro2002 @ Oct 10 2009, 10:30 PM) *
Its less obtrusive when located at the back.
(IMG:http://www.tangerineracing.com/images/EnginePics/BreatherCanInstalled.jpg)
On some engines, there are 1/2" dia. vent tubes on the heads, next to the intake ports.
The stock location is the best place to add them if your engine doesn't already have them, but it is a bit of work, especially when done with the engine installed.
Sometimes vents are added to the valve covers but they are below the tin so hose routing is a challenge.
kenshapiro2002
post Oct 11 2009, 07:23 AM
Gotcha...thanks. Guess my engine has no vent tubes. Hey.....did you clean all the baked beans outta that can before you started welding on it? (IMG:style_emoticons/default/lol-2.gif)
QUOTE(Racer Chris @ Oct 11 2009, 01:30 AM) *
tat2dphreak
post Oct 11 2009, 09:36 AM
stoya, stoya, stoya
my reason for moving it to the back is so I can put new insulation on the firewall. pretty simple.
ChrisFoley
post Oct 11 2009, 09:39 AM
QUOTE(kenshapiro2002 @ Oct 11 2009, 08:23 AM) *
My "baked beans" make Tangerine Racing Breather Cans more efficient at separating oil from the crankcase vapors, and returning them to the engine automatically, than any other product on the market.
You should seriously consider adding vents to the top of your cylinder heads.
kenshapiro2002
post Oct 11 2009, 11:51 AM
I have no insulation on my firewall.
QUOTE(tat2dphreak @ Oct 11 2009, 11:36 AM) *
kenshapiro2002
post Oct 11 2009, 11:52 AM
How do I do that while the engien is installed without getting shit in the engine?
QUOTE(Racer Chris @ Oct 11 2009, 11:39 AM) *
tat2dphreak
post Oct 11 2009, 01:03 PM
stoya, stoya, stoya
you can vent the valve covers with fittings, which isn't quite as good, but I have seen it. other than that, you would have to drop the engine, pull the heads and have a machine shop put the fitting in the proper head spot.
ejm
post Oct 11 2009, 02:02 PM
I can see the light at the end of the tunnel
I've drilled and tapped the heads with the engine assembled but not installed. You need to be careful when the drill drops thru not to hit the valve spring and to keep chips out of the engine.
kenshapiro2002
post Oct 11 2009, 02:25 PM
Yeah? How does one pull that off?
QUOTE(ejm @ Oct 11 2009, 04:02 PM) *
post Oct 11 2009, 02:50 PM
Resident German
QUOTE(Racer Chris @ Oct 10 2009, 06:12 PM) *
What? You don't like my Gatorade bottle ??? (IMG:style_emoticons/default/confused24.gif)
Gint
post Oct 11 2009, 04:21 PM
Mike Ginter
QUOTE(ejm @ Oct 11 2009, 01:02 PM) *
BTDT Pull the motor. Pop the valve covers off. Drill the head. Insert tube or thread the hole for pipe thread and screw in a fitting. On mine the hole I drilled ended up being a just a little too large for a true press fit. I used a piece of 7/16 or 1/2" (I can't remember exactly now) stainless steel tube. Mixed up a little JB weld and spread on the tube where it fit into the hole and then formed a very small bead around the tube at the top of the head. Done.
QUOTE(kenshapiro2002 @ Oct 11 2009, 01:25 PM) *
With the valve covers off and the motor put of the car it's easy to keep crap out of the heads while drilling. But watch that valve spring. (IMG:style_emoticons/default/smile.gif) I had to replace one of those while I was at it because I hit one with the drill bit.
kenshapiro2002
post Oct 11 2009, 04:57 PM
Looks better than that bean can. (IMG:style_emoticons/default/biggrin.gif)
QUOTE(SirAndy @ Oct 11 2009, 04:50 PM) *
ChrisFoley
post Oct 11 2009, 06:26 PM
QUOTE(kenshapiro2002 @ Oct 11 2009, 05:57 PM) *
Looks like you have your solution.
You'll have money left over for a wash and wax too.
(IMG:style_emoticons/default/bootyshake.gif)
kenshapiro2002
post Oct 11 2009, 07:30 PM
I'm just gonna stick a filtered cigarette on the end of the hose.
Seriously...since my heads aren't vented, I'm just looking for for a catch-all for the end of my filler vent hose that will vent to the atmosphere. Is there a specific breather can that just has a single entry point or do I need to block off some? I;m guessing Ill wind up with an EMPI type breather can.
QUOTE(Racer Chris @ Oct 11 2009, 08:26 PM) *
tat2dphreak
post Oct 11 2009, 08:27 PM
stoya, stoya, stoya
I think you'll have to block off some.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 22nd November 2024 - 05:51 PM
