Long stiffening kits |
ahdoman |
Oct 23 2009, 08:04 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Does any body make a stiffening kit that can be welded to the outside of the long?
ConeDodger |
Oct 23 2009, 08:12 PM
Apex killer! Group: Members Posts: 23,825 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yes but I am at a loss to remember who it is... do a search and there have been recent threads that discussed the options in this regard.
ahdoman |
Oct 23 2009, 08:36 PM
As always, I tried that already. The problem is the word "long" is in just about every post.
MDG |
Oct 23 2009, 08:38 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
AA sells the clamshells that go on the outside; I think they are a Restoration Design product
Grelber |
Oct 23 2009, 08:55 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I got mine from Brad Mayeur at 914ltd.
Bruce Hinds |
Oct 23 2009, 09:11 PM
V-8 madness Group: Members Posts: 734 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I bought a set many years ago from an outfit called Part Werks of Chicago. they go back and connect into the trailing arm mount too and really strengthen the chassis. Problem is they are heavy. I thought the strength would be good for my v8 project, but I never installed them.
If you want to check to see if they are still around, they were at 3750 N. Lake Shore Dr., Suite 7C, Chicago 60613 312-472-1096 They are substancial and come with a new jack tube and a support plate to hold it in place. I think I paid 200+ for these things about 20 years ago, I may let them go but haven't decided it I want to put them in or go through all the effort to replace the longs.... all the work these guys do on the cars is encouraging. B |
ahdoman |
Oct 23 2009, 09:56 PM
Thanks all.
The only thing I could find at AA is the replacement parts that restoration design makes. I believe these are the replacement shells and not a stoffening kit. Anybody got a web address for 914LTD? I found them on yellow pages but nothing more. Also nothing on Part Werks of Chicago except a couple of threads on club complaining about them. |
Heeltoe914 |
Oct 23 2009, 10:27 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Steve what is your purpose? Are you looking to repair of stiffen the chassis? I for one think the inside eggman??? Are the best IMHO.
Attached image(s) |
tat2dphreak |
Oct 23 2009, 10:30 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE I got mine from Brad Mayeur at 914ltd. THIS is the one you WANT. it ties the suspension to the long for more rigidity. great product. |
Heeltoe914 |
Oct 23 2009, 10:34 PM
I am sure Brad makes good stuff. anyone have pics of his kits?
ahdoman |
Oct 23 2009, 10:48 PM
Unfortunately it looks like "the turd" has a sag problem on the drivers side. I think there's rust inside the long but it hasn't made it's way through to the outside. The bottom seam flexes a little. I need something to "clamshell" the rear portion starting about 10" in front of the jack point and extending back to where the long curves up. Andys came through with a couple of pieces of stock that might work. I'm going to spend the day tomorrow cutting, grinding & welding.
dakotaewing |
Oct 23 2009, 11:20 PM
Senior Member Group: Members Posts: 1,163 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Here is a few pics of one of Brads older kits with a few of my own modifications...
Im the last pic you will see a gap between brads kit and the top of the long - This is where I addes some additional 1/4" square rod to brad kit to fill the gap, later welding this area as well - Attached thumbnail(s) Attached image(s) |
r_towle |
Oct 23 2009, 11:22 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
George Hussey (AA) designed the original clamshell overlays that weld onto the outside of the long.
Its meant to go on very tight, it should help aline the car... Rich |
pete-stevers |
Oct 23 2009, 11:54 PM
saved from fire! Group: Members Posts: 2,644 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
not sure but i think chappy has them installed on his crazy turbo
Rand |
Oct 24 2009, 12:02 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Just check it all out. There are some very knowledgeable folks who say the inner side is where the strength is. The outer is just a shell and reinforcing that does more to add weight than strength.
The outer shells have some questions. Engman's inner is without question. Personally I hate adding weight, so I make damn sure it counts. For me that means Engman style in the cabin, and some very carefully placed bracing between the firewall and suspension ears, plus tie the rear shock tower tops to the longs better. |
shoguneagle |
Oct 24 2009, 01:15 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I went to both extremes - I welded Brad Mayeur's kit to the external of the longs "after making sure/making rust repairs" to the original longs. In addition, I welded the inner stress kit into my car. I believe without checking the kit belongs to Engman but check the suppliers listed either on this board or the other one to ensure I am right. I maybe giving credit when it belongs to someonelse. They both work together quite well.
I purchased another outer long stress kit but do not remember who made it. I believe it was the sheet metal parts provider who was recently bought out by someone from Canada. Hope this helps. Steve Hurt |
Cire |
Oct 24 2009, 06:19 AM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
Steve what is your purpose? Are you looking to repair of stiffen the chassis? I for one think the inside eggman??? Are the best IMHO. Got any more pictures of you putting in the long stiffener? What are your thoughts on if you had to do it again... Would you do it the same way? Did you do the back first and connect the two sides? Did you do two sides and connect the back? I also see you have some epoxy or sealer or something in your pictures. Whats that for? = ) Please tell all. Eric |
Grelber |
Oct 24 2009, 07:57 AM
Cire |
Oct 24 2009, 08:49 AM
Here's a pic of my passenger side with the Brad Mayeur long kit welded in, and painted, etc. We put the new jack posts on as well. I also put in the Rich Johnson rear console stiffening kit as well (way overkill, but hope one day to have some serious horsepower). Looks great. Did you do the work yourself? Do you happen to have more pictures? How much was the Brad Mayeur long kit? How long did it take you to get it welded in? If you had to do over would you stay with the style you selected or would you go to the internal long stiffeners? I had 30 more questions but I will slow down a bit. = ) Thanks again for the great info. = ) Eric |
carr914 |
Oct 24 2009, 09:28 AM
Racer from Birth Group: Members Posts: 122,011 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Lo-Fi Version | Time is now: 25th November 2024 - 12:57 AM |
