dm930 |
Newbie ![]() Group: Members Posts: 1 Joined: 23-August 03 From: Huntington, NY Member No.: 1,069 ![]() |
1973 Porsche 914-6 Race Car
Affectionately Known as "The Atomic Creamsicle" Over $60000 invested in this car over the past 6 years. Dyno'd at Dawe Motorsport on Mustang Dyno w/ 206 RWHP Car weighs 1890 lbs w/ 1/4 tank of fuel without driver (runs on 93 octane pump fuel) One of the quickest and most dependable autocross cars in the East Coast Car is well known throughout Metro NY PCA / BMWCCA / NASA NE Raced in Nasa NE in 2009 with 5 poles, 5 wins and 3 track records including Limerock Park (58.4) All 5 races with in-car video and data aquisition. Link to website below "Car went out in practice at Watkins Glen last month in the wet on sticker slicks and tapped the armco. Mostly cosmetic fiberglass damage. We were able to repair it to get out next morning, but had an over rev and bent some valves. Pictures before WGI and after WGI are linked below." Selling car for $17500 as I am looking to cut my losses and move on to new project waiting dm914racer@gmail.com or 631-445-3349 Cell Demetri Pre WGI http://s193.photobucket.com/albums/z108/dm...0Before%20Sale/ Post WGI http://s193.photobucket.com/albums/z108/dm...6%20For%20Sale/ Video link - http://vimeo.com/dm914/videos Engine 2.9 liter twin plug Electromotive Dual Ignition, Crankfire System 7R Case PMO 46mm carbs Andial 2.9 litre P&C's 9.8:1 compression Patterson 3 gallon Oil tank with internal scraper system -12 and -16 AN Fittings Web Cam welded and ground cams Carrera Tensioners Sachs Sport Clutch "S" Crankshaft Fully balanced rotating internals Lightened and Balanced Flywheel Relocated remote oil filter housing Transmission 901 Side Shifter Gearbox Rennshift Short Shifter Patrick Motorsport solid shift linkage Solid Tranny and Engine Mounts Stock gear ratios Suspension / Braking / Steering 930 front and rear calipers w/Pagid RS-29 Yellow Front Slotted Floating Rotors / Rear Cross Drilled Rotors 23mm Master / Steel Braided Lines / Castrol SRF Wilwood Brake Proportioning Valve Brake Ducting and Hoses Fox F&R Externally Adjustable Coilovers w/adjustable spindles and remote nitrogen reservoirs ERP 935 style front suspension and crossmember Reinforced rear trailing arms w/new bearings, hubs Elephant Racing bushing kit 911 steering rack Exterior Full Fiberglass body kit Rear custom fabricated and adjustable high wing LED brake lights Long wheel studs 2 sets of 15x8 Fuchs wheels w/ Hoosier Slicks (1 set are NEW) 1 set of BBS wheels with Brand NEW Hoosier Rains Exterior battery cut-off switch Fluidyne 24"x2"x6" front mounted oil cooler Mocal secondary oil cooler in left front fender Interior Extensive 1.5 roll cage w/Nascar Bars Kirkey Racing Seat Willans 5 point harness Adjusted Brake Pedal for proper heel/toe shifting Schroth Window net and Center net Full view rear mirror and side mirrors Odyssey PC-925 race battery ATL Fuel Cell Aeroquip steel lines throughout Fully Fabricated Wiring harness w/fuse block and circuit breakers Removable Instrument Pod w/quick disconnects Longacre switch pack with Auto Meter guages Halotron Fire Extinguisher |
dm930 |
SOLD...
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:26 PM |
