daveyboybadion |
Member ![]() ![]() Group: Members Posts: 108 Joined: 19-January 06 From: Seattle, WA Member No.: 5,437 Region Association: Pacific Northwest ![]() |
I'm in the planning stages of converting my '73 914 to an electric vehicle and need some help in figuring out how to lock out 1st gear. I saw a pic on the Road Glue site but I'm not sure what was done or how to do it.
Jump in any time Dr.Evil....daveyboy |
McMark |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Easy. You get a section of copper tubing (I forget the i/d), remove the 13mm bolt that holds the 1/R shift fork on, remove the fork, insert the pipe on the rod, reinstall the fork and slider and you are set (IMG:style_emoticons/default/smile.gif) Pretty easy. To do it 1 better, remove the big bolt at the end of the stack, remove the slider, and the carrier, then remove the 1st gear all together. Leave the race in, reinstall the carrier, 1/R slider, pipe section, and enjoy.
Clear as mud? I can take pics. |
Dr Evil |
That thread does not cover it very well. I'll shot some pics I have a stock somewhere. |
McMark |
I was thinking user-controllable lockout. Whoops! (IMG:style_emoticons/default/pinch.gif)
Dr Evil |
Ah, I see (IMG:style_emoticons/default/smile.gif)
Dr Evil |
Here is a pic from my rebuild thread.
I - shift fork, held on by one 13mm bolt II - 1st gear III - 1/R slider By putting a pipe on the rod for the 1/R gear, you block it from moving (in this picture down) forward thus it can not engage 1st. Your stick will not move in that direction. The pipe cost under $5. The paper seal for the tail cone can be gotten from Mikey914 for $5 Attached image(s) ![]() |
daveyboybadion |
Thanks y'all that's got it...daveyboy
Lo-Fi Version | Time is now: 25th June 2024 - 04:55 PM |
