my928s4 |
Member ![]() ![]() Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest ![]() |
Was cleaning the area with the wire brush attachment and this area was worse than I thought. Just wondering what is the right way to do this before I go and make a mess of things.
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Wire fed welder.....
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,734 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Yes, the absolute best way to repair this is with metal. However an area this small can also be suitably repaired with POR15 and PORPatch, which is an epoxy.
Unless this is a concours repair, a cold patch could be the easiest way to go. |
my928s4 |
Wire fed welder..... My main concern there was those holes were going to get a whole bunch bigger before you could find something to weld to. Yes, the absolute best way to repair this is with metal. However an area this small can also be suitably repaired with POR15 and PORPatch, which is an epoxy. Unless this is a concours repair, a cold patch could be the easiest way to go. This area will be hidden with the seal anyway so that is an option. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:03 PM |
