VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,470 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Okay, its time to start my winter projects, and start the thread to keep me motivated and honest.
36/37 complete! And its no longer winter, so thats JUST GOING TO HAVE TO DO! Tasks to complete: 1) Front End Electrics.
Items may be added as found. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,691 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
Speaking of soundproofing the doors, when I pulled the door panels off my doors to adjust the windows, there was plastic adhered to the door frame. I took it off and didn't replace it. What is the plastic for and should I replace it? Was it soundproofing?
I'm told a shift boot for a '73-'86 911 with the 915 trans will work for the Rennshifter. |
SirAndy |
Was it soundproofing? No. It's air-proofing ... Without the plastic, you can feel a draft of outside air coming through the door panel gaps when driving at speed. (IMG:style_emoticons/default/shades.gif) Andy |
VaccaRabite |
Was it soundproofing? No. It's air-proofing ... Without the plastic, you can feel a draft of outside air coming through the door panel gaps when driving at speed. Its main purpose is a moisture barrier though. Water gets inside the doors, and you DO NOT want that moisture to get at the pressboard door panels, or they warp quickly. The plastic is there to keep the water off the door panels. Zach |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
A suggestion to add to your list.
Research the local mud bog events Attend at least two or three. Research tractor pulls Attend at least two or three. Rich |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
now that is a list.
good luck with it. me and the girls are here to help (IMG:style_emoticons/default/beerchug.gif) |
saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Zach:
A most impressive list! Good luck with everything. My list is much less detailed: 1. Have car driveable for the Mid Engine Invasion next year at Hershey. Bob |
VaccaRabite |
Fuse is fixed.
I bought new H4 lights, just in case that was the problem. It was not. But I adjusted the headlight while I was in there. Zach |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I dont see mention of my bus anywhere on that list (IMG:style_emoticons/default/poke.gif)
jsayre914 |
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
Zach, correct me if I'm wrong; but shouldn't the caution light knob illuminate dimly when the light switch is activated?
Mike |
VaccaRabite |
Kirmizi |
LOL Zach!
Hopefully someone can chime in sooner, but I'm going to check mine tomorrow just to be sure. Little too nippy outside right now. Mike |
VaccaRabite |
It appears that my caution light switch is supposed to do that. AWESOME! I'm just going to call that one a win, and move on. One less thing to do!
Zach |
r_towle |
Monster Mud Bog competition
Rich |
VaccaRabite |
VaccaRabite |
I got the 40IDF carbs in the mail from Todd today. Hopefully I'll be able to start tearing them down tonight to see what I need to order in terms of jetting.
Thanks man! Zach |
VaccaRabite |
Big one checked off the list today. All my headlights work again. My headlights did not have the plugs at the end, and I had mis-wired one. Don't know why it worked for a while wired wrong, but it is fixed now. Lots of thanks to Mike for helping me trouble shoot it.
Zach |
VaccaRabite |
Another notch done. Just put the new lock cylinders from Herb into my door handles. Now I can park and lock my car!
The handles will go back in when I finish the sound proofing and put my doors back together. Now I am going to go tear into carbs. I took today off to work at home. Called in at noon to find out why my project had not been updated from my helper. "Oh, I got someone from word processing to do it, enjoy your day off." Kinda cool, I guess. Except that I spent 4 hours this morning working on a template that will now never be used. Silly underlings. Zach |
Lo-Fi Version | Time is now: 18th June 2024 - 07:34 AM |
