Dashpad question, difference between years? |
mepstein |
Jan 17 2010, 09:55 AM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there a difference between years for the dashpad? Will a 75 fit in a 70 car without modification? Thanks, mark
914Sixer |
Jan 17 2010, 10:05 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All the dashpad are the same. The texture of the early pad is said to be different. All the tops I have seen over the years appear to be the same. I have noticed suttle differences in the texture of the ashtray pull.
kconway |
Jan 17 2010, 10:07 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Isn't the relief around the glovebox a little different early to late years?
tradisrad |
Jan 17 2010, 10:11 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
If you are talking about the dash with the ash tray part they are different. The glove box relief on the 70-72(maybe to 71) is larger and your glove box will not open all the way with a 73 and later dash.
I've got a nicely recoverd '73 dash and I did not use it in my '70 car because of the glove box reilief. |
mepstein |
Jan 17 2010, 10:15 AM
If you are talking about the dash with the ash tray part they are different. The glove box relief on the 70-72(maybe to 71) is larger and your glove box will not open all the way with a 73 and later dash. I've got a nicely recoverd '73 dash and I did not use it in my '70 car because of the glove box reilief. I'm talking about the large vinyl covered foam pad that covers the top of the dash, not the actual metal dash. |
kconway |
Jan 17 2010, 10:18 AM
If you are talking about the dash with the ash tray part they are different. The glove box relief on the 70-72(maybe to 71) is larger and your glove box will not open all the way with a 73 and later dash. I've got a nicely recoverd '73 dash and I did not use it in my '70 car because of the glove box reilief. I'm talking about the large vinyl covered foam pad that covers the top of the dash, not the actual metal dash. Yeah, so are we. If you look at the area where the glovebox is there is a relief in the pad to allow the glovebox door to swing up. Early to late are different size reliefs. |
sixerdon |
Jan 17 2010, 10:24 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
First, there are two variations of the dashpad. Early '70 - '71 and late '72 - '76. The change was when the side vents were introduced in '72 making the glove box and door smaller in width.
To answer your question, the late dashpad will fit on early dashes, but the glove box door will not open all the way causing scuffing to the relief on the underside of the dashpad. Just be careful opening the g-b door. Mine has been in place for over 10 years until I can find a quality substitute. It doesn't show unless one knows what they are looking for. Don |
mepstein |
Jan 17 2010, 11:26 AM
Thanks all for the info.
SirAndy |
Jan 17 2010, 01:04 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
First, there are two variations of the dashpad. Early '70 - '71 and late '72 - '76. (IMG:style_emoticons/default/agree.gif) A '75 dash-pad will not fit into a '70 car without modifications. (IMG:style_emoticons/default/shades.gif) Andy |
sixerdon |
Jan 17 2010, 02:04 PM
First, there are two variations of the dashpad. Early '70 - '71 and late '72 - '76. (IMG:style_emoticons/default/agree.gif) A '75 dash-pad will not fit into a '70 car without modifications. (IMG:style_emoticons/default/shades.gif) Andy Not true, Andy. It has been fitted on my car without without mods. Just careful on opening door. No problem. Don |
SirAndy |
Jan 17 2010, 03:00 PM
Just careful on opening door. No problem I'd call that a problem (IMG:style_emoticons/default/biggrin.gif) Some people don't like to be careful ... (IMG:style_emoticons/default/shades.gif) Andy |
70Sixter |
Jan 19 2010, 01:53 PM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
...the late dashpad will fit on early dashes, but the glove box door will not open all the way causing scuffing to the relief on the underside of the dashpad. Just be careful opening the g-b door. Mine has been in place for over 10 years until I can find a quality substitute. It doesn't show unless one knows what they are looking for. Same here. My glovebox door does not fully open. I just know there is a nice early dash cover out there with my name on it! |
Lo-Fi Version | Time is now: 27th December 2024 - 10:53 AM |
