detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Awhile back trying to fix a trunk issue and while removing the torsion bars one of the Torsion Bar Placement Holder bolts sheared off, currently using trunk shocks that I do not care for anymore.. I want to re-install the torsion bar system but need advice on repairing/replceing the sheared off bolt..
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
You have a couple options:
* Grind it down and weld a new stud on * Use a nut-sert and new stud or bolt. I really love nut-serts... |
detoxcowboy |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Grind it down and drill through with a nut and bolt, if you're not a welder??
ps. why are you dropping the shocks? I was just considering buying a set to get rid of the torsion bars?? |
zx-niner |
Member ![]() ![]() Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California ![]() |
Just installed a set of the shocks from Camp 914. I'm very pleased with the look and function. Trunk operation is smooth and light. Removing the torsion bars also cleaned up the engine bay.
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I have the Camp 914 trunk lid shocks on both trunks of both cars and they work great. Mine are mounted a little differently and the roof fits in the trunk perfectly.
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
The instructions show it connected to the trunk hinge and then a cut on the body just a bit. 3 screws to the underside of the channel for the trunk seal.
McMark |
Yep, the red car pictured has them installed 'uniquely'. Following the instructions from Camp914 results in a setup that works without interfering with the targa top.
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Yep, mine are installed like this, and the targa fits perfectly (even with that big box in there lol)
http://gallery.me.com/rodericdavies#100050...p;bgcolor=black |
Elliot Cannon |
Correct installation = easy roof stow. (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) ![]() ![]() ![]() |
zx-niner |
I bet your roof doesnt fit in your trunk anymore... Yeah, it would be a bigger deal if I ever took the top off. I know it's heresy but open air driving is not my thing. If someone made a steel top conversion kit, or better yet did the conversions for a price, I would be so in on it. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Interesting different perspectives. I only put the top on if I need to keep precip out of the cabin.
I don't get all the Qs about the top fitting between the shox. It fits easily!! Oy. Just set it up right, there's plenty of room! If you can't fit the top between the shox, you have a nasty hack job. I haven't seen one of those yet... Do they exist or are people making ASSumptions? |
Lo-Fi Version | Time is now: 25th June 2024 - 09:20 PM |
