> Tires again 205 50 or 60
jhelgesen
post Feb 12 2010, 08:34 AM
I've got a set of 2.0 fuchs to put on my stock fendered 75. Checking out tirerack, I can get 205/50's or 205/60 in Kumho's. Street car only.
Any fender issues with using the 60's?
Thanks!
Replies(1 - 19)
detoxcowboy
post Feb 12 2010, 08:48 AM
Region Association: Africa
QUOTE(jhelgesen @ Feb 12 2010, 06:34 AM) *
Thanks!
No sir, I have 205/60 all around my 74 w/ 2.0 fuchs.. so do other people..
jhelgesen
post Feb 12 2010, 08:50 AM
QUOTE(detoxcowboy @ Feb 12 2010, 09:48 AM) *
Thanks!
Sweet! What I needed to hear. I'll get them on order!
zx-niner
post Feb 12 2010, 12:52 PM
You will be much happier with the engine revs using 60s since you'll be mostly on the street
6freak
post Feb 12 2010, 01:16 PM
MR.C
205/50/15 NO ISSUES
GO WITH THE BIGGEST YOU CAN
6freak
post Feb 12 2010, 01:28 PM
MR.C
QUOTE(zx-niner @ Feb 12 2010, 10:52 AM) *
Maybe im all messed up but arent 50`s wider then 60`s
205 tire height
50 tire width
15 rime size
why would 60 affect the revs and why would you put on a skinner tire then you have too??
Lavanaut
post Feb 12 2010, 01:43 PM
Hungry Mind : Thirsty Gullet
205 = width, 50 = sidewall height. 60 is closer to stock diameter, hence lower revs at same speed than with the 50s.
Reid
championgt1
post Feb 12 2010, 01:44 PM
Don't embarrass me Filmore!
Mike you have height and width mixed up.
6freak
post Feb 12 2010, 04:01 PM
MR.C
QUOTE(Lavanaut @ Feb 12 2010, 11:43 AM) *
Reid
THANKS FOR SET`N ME STRAIT (IMG:style_emoticons/default/smile.gif)
messix
post Feb 12 2010, 04:13 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
QUOTE(6freak @ Feb 12 2010, 03:01 PM) *
Reid
got your asshat on again huh? (IMG:style_emoticons/default/av-943.gif)
70_914
post Feb 12 2010, 04:21 PM
QUOTE(6freak @ Feb 12 2010, 02:01 PM) *
Reid
Actually, to be more specific- 205=mm width (tire manufacturers measure at different spots so they are not all the same width. 50 or 60 is the aspect ratio. 50% the width tall, 60% the width tall, etc. So an sr16515 (which should be a 70 series) has a sidewall that is theoretically 115.5 mm tall. 205/50 should be 102.5, 205/55 should be 112.75, 205/60 should be 123.
Taller tires = numerically lower gearing = no power around town, good RPM on the freeway.
Kevin
Shade Tree
post Feb 12 2010, 05:44 PM
I have 205/60's. I like the ride and the look. I think the taller tire fits the vintage of the car. However, I feel like I'm lugging the poor thing if I use 5th gear going 60mph. Since I almost never go any faster on a normal commute, I'm now sort of wishing I had the 50's so I would have a better chance of using 5th. 50's are a pretty bumpy ride imo.
jsayre914
post Feb 12 2010, 06:14 PM
Speed Up !!!
this is my second 914 and i have 205/60 on this one and the lasdt one. if you are driving 120+ miles daily, its not an option. I drive my car as hard as i can untill it breaks, then i take too long to fix it, and go again (IMG:style_emoticons/default/driving.gif)
i also love the look of the 60's
detoxcowboy
post Feb 12 2010, 06:22 PM
QUOTE(Shade Tree @ Feb 12 2010, 03:44 PM) *
I have heard 50's are bumpy, never had a problem with 5th gear on 60's but in Los Angeles it is either 1st/2nd gear on the freway or 80 mph just to keep up..
EdwardBlume
post Feb 12 2010, 06:30 PM
I liked 205 / 60 s with a 1/4 inch spacer. Filled out nice! You need longer bolts for the rear though...
markb
post Feb 12 2010, 08:31 PM
914less :(
I've had 205 70's, 60's & 50's, and I prefer the 60's. I drive a lot of highway miles, and they're better for me on the highway. I currently have 70's on the car, and can't wait to get back to 60's.
Michael N
post Feb 12 2010, 09:34 PM
Certifiable
205-60-15.
sww914
post Feb 12 2010, 09:48 PM
50's on my racecar, 60's on my street car. I'm buying new street tires soon, I'll put 60's on again. They're just right.
6freak
post Feb 12 2010, 09:58 PM
MR.C
QUOTE(messix @ Feb 12 2010, 02:13 PM) *
Reid
Always ....hey thanks again for coming over last Saterday Troy
messix
post Feb 12 2010, 10:46 PM
QUOTE(6freak @ Feb 12 2010, 08:58 PM) *
Reid
you know my situation now, i'm sorry i couldn't make it. i sent a gift though.
- Lo-Fi Version Time is now: 5th January 2025 - 01:49 AM
