scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
I'm putting together an 1835 I had in my Baja years ago, before I knew what I was doing. I originally used Weber progressive which in hindsight I realize was the main reason I melted number 3.......twice (IMG:style_emoticons/default/dry.gif) The case is a VW f.i. case, lign bored by one of the best around here, heads WERE stock, That's where my ? comes in. I know when I used to be into VW's hardcore the 041's were the things for a mild streeter. Now with the advacements of the last 15 years what is recommended ? 044's? How about carbs ? 40 IDF's ?
I'm well aware of the issues with 92's but I already have 2 1/2 sets of near new ones so that is what I will be using. (IMG:style_emoticons/default/dry.gif) What I have for it : c.w. 69 mm crank 92mm Mahles Engle 120 cam balanced stock rods ( unless someone has something nicer for a good price (IMG:style_emoticons/default/biggrin.gif) ) full flow high flow pump sump extractor from a Euro high tuck system, will probably run a stinger on it Heads ??? Carbs ????? other suggestions ?????? |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Feb 14 2010, 01:58 PM)
![]() I'm putting together an 1835 I had in my Baja years ago, before I knew what I was doing. I originally used Weber progressive which in hindsight I realize was the main reason I melted number 3.......twice (IMG:style_emoticons/default/dry.gif) The case is a VW f.i. case, lign bored by one of the best around here, heads WERE stock, That's where my ? comes in. I know when I used to be into VW's hardcore the 041's were the things for a mild streeter. Now with the advacements of the last 15 years what is recommended ? 044's? How about carbs ? 40 IDF's ? [/quote] I'll sell you an "n". =o) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) I'm interested in your build. (IMG:style_emoticons/default/popcorn[1].gif) |
scotty b |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
i would like to build up an engine for the single cab
but i need to find some dollars... and it needs so much body work patina is such a dirty word in my world |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
What is this going into, Scotty?
scotty b |
What is this going into, Scotty? 356 (IMG:style_emoticons/default/shades.gif) Just thinking ahead. I finished up the engine for the Puma and have the bug ( pun intended ) to get back into the VW engine world again. I really kind of miss it. I'm working on an AMAZINGLY good potential deal for the bus motor. (IMG:style_emoticons/default/smile.gif) My friend with the P-shop called me last week about an older guy he met that has several 3.0 SC motors and trannies. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/aktion035.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Lose the 92's unless you get the 94mm register jugs, get the 90.5mm jugs and slugs.
If you want heat I'd use ported and polished stock valve heads, still will pull like a truck. Engle W120 may be a bit much, I love the W110 my favorite cam for the street. Keep CR to around 8:1 for street. You don't need "better" than the stock rods, I've built a 200+hp turbo with stock rods. If you plan on drag racing burnouts then maybe... 041's are crap, if you can find old stock 040 great if not than the CB heads are OK, just don't get the heads with giant ports, small ports are better for a street car.. Dual 40IDF unless you can source a good set of Gene Berg 42mm specials, weber DCNF's (The ultimate Type 1 street cruiser carbs but no good for AX and racing). Dell's are OK but parts can be a pain and webers are plentiful. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:43 PM |
