mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
I took the tank out to clean it and put in a new screen. This picture is inside the tank after the screen sock was removed. The car was running really well. The new screen should help even more!
Attached image(s) ![]() ![]() |
kkid |
Member ![]() ![]() Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
Good for you!
Have you put the tank back in the car? How did you clean the tank anyway? Was the sock dirty? I am interested because this will be my next project. I believe my tank has never been cleaned in its life. Thanks for posting! |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
looks normal, cleaned mine first year I had it
johnnie5 |
914 lover ![]() ![]() Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California ![]() |
Yep. Did mine 1st thing too. I used Eastwood's etch and sealer kit... worked great!
http://www.eastwood.com/ew-gas-tank-sealer...s-for-cars.html I did not dilute the muriatic acid as Eastwood says to though.... just went with straight acid! Diluted mixture was not nearly strong enough to cut through the rust. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Let me know how that new screen goes in...
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
I am amazed at that picture, fish eye camera w/ surgical lighting??
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I used the POR15 gas tank kit. Three part, Marine Clean, Something else I don't recall and the POR15 paint. Took about two hours over a couple days. Looks like new.
jonferns |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States ![]() ![]() |
The POR kit does a nice job of cleaning and sealing, I use it on beetle tanks at work all the time. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I used POR-15 as well with great results. The radiator shop down the road from me will boil it clean and seal it with an epoxy resin for $50. Check around.
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
Yes, the radiator shop for cleaning is good advice.......But I
tossed the sock, I just use fuel filter's....No problems in mucho years (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/bye1.gif) |
kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
I used a product by KBS Coatings that worked pretty well. Cleaned, etched and coated.
Lo-Fi Version | Time is now: 26th June 2024 - 06:18 AM |
