Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
With a punch!
We did it at the clinic on mine! |
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
It is your standard roll pin. Just clamp it down in a vice and use a drift or punch to drive it out. The hardest part is finding the most appropriate way to get it in the vice, as the assembly is somewhat awkward.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Yup, what they said (IMG:style_emoticons/default/smile.gif)
bigkensteele |
I am but one of the Doc's grasshoppas.... |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
As a witness to said clinic, put some arm into punching it out...
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Looking at the rust and pits on the arm and shaft, I'd start with a lot of PB blaster or other penetrant. Removing the shaft from the arm will be the next bit of fun if the shaft is corroded. The parts are machined to have a tight (no slop) fit and the diameter increase from the rust might prevent/ inhibit removal. Save the roll pin, it's a not easy to find that size and has extra coils for strength
Just don't do like my DAPO and use a drywall screw as a roll pin replacement (IMG:style_emoticons/default/blink.gif) |
Crazyhippy |
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None ![]() |
Anyone have an extra arm like that floating around? i could use one (IMG:style_emoticons/default/piratenanner.gif)
Dr Evil |
I may have one. PM me to remind me and I will look.
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 AM |
