I need a photo please, '74 vapor canister |
Lennies914 |
Mar 6 2010, 10:31 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I'm ready to install a 2.0 in my '74. When I got the car it had a blown 1.8 (out of the car). I do not have the vapor lines going to the fuel tank area, but I do have the canister that came off the car (with short hoses on it). I'm assuming it was mounted in the engine compartment, I just don't know where. Any pics would be much apprecieated. (IMG:style_emoticons/default/confused24.gif)
Mike Bellis |
Mar 6 2010, 10:43 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I think the 74 is different from my 73. The vapor hoses run from the drivers side front trunk, inside the front fender, under the rocker panel, into the engine bay. My canister bolts the the front trunk brace, next to the tank.
Sorry I can't help with pics of a canister mounted in the engine compartment. You should still have at least one hose running back there for the connection from the expansion tank. |
ClayPerrine |
Mar 6 2010, 10:51 PM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
On the 74 and later, there was only a small plastic line running down the tunnel next to the fuel lines. The canister actually mounts in the engine compartment, either on the batt tray, or on the back wall. The bigger lines go to the fan and air cleaner.
There is a diagram on the bird board........ |
tod914 |
Mar 7 2010, 12:06 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
74 2.0 I had, it was located on top of the drivers side area of the gas tank. I'll see if I can find a shot for you.
70_914 |
Mar 7 2010, 12:46 AM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
I'm ready to install a 2.0 in my '74. When I got the car it had a blown 1.8 (out of the car). I do not have the vapor lines going to the fuel tank area, but I do have the canister that came off the car (with short hoses on it). I'm assuming it was mounted in the engine compartment, I just don't know where. Any pics would be much apprecieated. (IMG:style_emoticons/default/confused24.gif) (IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/trunk.jpg) 1974 1.8, mounted to fuel tank. Same as my 1970 1.7. (IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF0934.jpg) |
Dave_Darling |
Mar 7 2010, 02:49 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Up through "early 74" (unsure of date or VIN cutoff), the charcoal cannister was on top of the fuel tank as shown in the photos above. Look for two plastic hoses running along the driver's side longitudinal, behind the rocker cover. Those are for the hoses from the fan shroud to the cannister, and from the cannister back to the air cleaner.
The "late 74" and on cars have the cannister mounted in the engine bay, either on the battery tray or on the rear bulkhead of the bay. Look for a single small line going through the center tunnel and coming out into the engine bay right next to the fuel lines. That is for the line from the expansion tank to the cannister. --DD |
Lennies914 |
Mar 7 2010, 09:35 AM
Dave, you are correct. I must have the later model. There are no holes in the inner ds fender for hoses, so I'm certain that it was not on the tank. Was just hoping for a pic as to where in the compartment it was mounted.
Thanks for everyones responses. LW |
Mike Bellis |
Mar 7 2010, 05:09 PM
Pic of a surviving 75
Lennies914 |
Mar 7 2010, 09:33 PM
Pic of a surviving 75 (IMG:style_emoticons/default/beerchug.gif) Thank you Mike. That's exactly what I needed. |
Katmanken |
Mar 8 2010, 09:52 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
My late 74 had the cannister mouned on the rear bulkhead of the bay on the passengers side. In the picture above of the red car, the cannister would lay longitudinally right in front of the large rear trunk lid and cut down on access through the opening.
There was a pem stud punched into the bulkhead into the engine compartment, and a big loop secured the cannister to the stud. Not very secure design as the stud pulled loose from the bulkhead and is now something else to fix. My late 74 2 liter has the cannsiter on the gas tank, and a pair of lines running down the right rocker to the engine compartment. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:01 PM |
