Another 6 heat exchanger thread, Converting 4 exchangers to 6??? |
bigkensteele |
Mar 12 2010, 08:32 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
This thread probably won't last long, as I expect this will be shot down in short order, but... Would it be feasible to convert 914/4 heat exchangers to a six configuration by adding a separate pipe outside the shielding and merge it down past where the shielding ends?
Heat should be just as sufficient as if they were mounted on a 4. Not sure about pipe diameter vs. the various six headers/exchangers... Where I think this will be shot down is in the area of cylinder spacing and access to the head mounting studs. However, I am wondering if these two could not be overcome? Please fire away. I can take it. Just throwing it out there, as I have never seen this discussed. |
Cap'n Krusty |
Mar 12 2010, 08:38 PM
I'd give you a short answer, but I think a long, detailed, one is in order. No.
EXCEPTION: If you have the money, my friend, you can do anything .......... The Cap'n |
bigkensteele |
Mar 12 2010, 08:41 PM
Lo-Fi Version | Time is now: 26th June 2024 - 11:28 AM |
