Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
The carbs for my 2.7 are the 40 IDTP 13C. I called PMO to get jet suggestions. While they were very specific on idles, main and a/c , I told them I already had F1 emulsions and they said "those will work". Thats fine - I trust them - and I plan on using them.
However, all of the charts and maunals I have been able to locate (including the webber book) list the F-26 or F-3. I understand that a larger/smaller jet simply means getting more or less of what ever it is you are regulating. I dont quite get what the emusion tubes do and how. Can anyone throw me a laymans explanation? Thanks! Scott S |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 943 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
See:
http://www.aircooled.net/gnrlsite/resource...les/jetting.htm From the article: Lastly, you have emulsion tubes to change "where" it's rich, lean, etc. Emulsion Tubes: The Emulsion Tube mixes air from the air corrector jet with fuel from the main jet, and controls the mixture from the discharge nozzle at all engine speeds that the main jet is working! Basically, the Emulsion Tube changes the diameter and location of small holes in it's body. For Weber IDF carbs, the F7 or F11 is usually what you need. The F "series" has no rhyme nor reason to the numbering system, so you can't tell anything by the number unless you look it up! But, with these two examples, the F7 richens the mixture up at the bottom of the RPM range and under acceleration, while the F11 leans the mixture out on the top end a little bit, and is usually used (high RPMs) when you use air jets larger than 200. See: http://www.rhinoracing.com/yaw/carb_tuning.htm From this article: Emulsion Tubes The air from the air bleeds enters the main circuit through the emulsion tube. The emulsion tube has a series of small holes from top to bottom, and it is through these holes that air enters the main circuit. At low engine speeds, when fuel demand is low, these holes are submerged in fuel, and so no air can flow through them. As engine speed increases, the fuel level in the float bowl drops, uncovering these holes, and allowing air from the bleeds to enter the main circuit, thus leaning the mixture. As the engine speed increases further, the fuel level in the float bowl continues to drop. This uncovers even more of the holes in the emulsion tube, which makes the air bleed have a greater effect on the mixture. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,926 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Scott,
when you get this baby running... I can loan you a set of F3's to try out but the above answer covers it the emulsion tubes affect when and how the mid transitions occur they can help elimnate stumble you can also use air corrections to affect transition as well its all a black art. The innovate helps. The weather matters and the particular engine characteristics and compression play a roll also |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Yeah well........Mazda guys.
Emulsify means mix. The vacuum draws fuel up and around the Etube mixing air....drawn by the same vacuum ...into the fuel through those holes aerating the fuel. I have this good pic (drawing) but my scanner is broke and I can't load the pic. If the fuel in your float bowls drops, you need a better fuel pump/delivery plumbing. The rest of the answers look good. |
Lo-Fi Version | Time is now: 6th April 2025 - 06:16 AM |
