19mm Master Cylinder ground wire, oops |
flipb |
Apr 15 2010, 07:29 PM
Senior Member Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
My '74 has a 19mm Master Cylinder.
The dash warning light has been flashing incessantly - I disconnected it a while ago. Tonight I was busy breaking my horn mechanism in the steering wheel (IMG:style_emoticons/default/blink.gif) and I decided to try to reset the button on the MC to stop the flashing. Here's the deal. With the car on the ground and a flashlight, I managed to find the reset button. Hit it, reconnected the warning light on the dash, and it now functions correctly. (stops when the parking brake is released) However while I was reaching in there, I accidentally disconnected what looks like a Ground wire. I don't think I have any hope of finding where it connects without taking the car to a shop and getting it up on a lift, so... What is the risk of driving it with the ground wire disconnected from the MC? I don't think I've ever fixed something on this car without (IMG:style_emoticons/default/sheeplove.gif) something else. If it's not one thing, it's another. (Or as Freud put it: If it's not one thing, it's your mother.) |
dr914@autoatlanta.com |
Apr 15 2010, 07:43 PM
914 Guru Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
early cars two prong switch late cars single prong switch. the factory figured out that the switch can ground through the master cylinder!
My '74 has a 19mm Master Cylinder. The dash warning light has been flashing incessantly - I disconnected it a while ago. Tonight I was busy breaking my horn mechanism in the steering wheel (IMG:style_emoticons/default/blink.gif) and I decided to try to reset the button on the MC to stop the flashing. Here's the deal. With the car on the ground and a flashlight, I managed to find the reset button. Hit it, reconnected the warning light on the dash, and it now functions correctly. (stops when the parking brake is released) However while I was reaching in there, I accidentally disconnected what looks like a Ground wire. I don't think I have any hope of finding where it connects without taking the car to a shop and getting it up on a lift, so... What is the risk of driving it with the ground wire disconnected from the MC? I don't think I've ever fixed something on this car without (IMG:style_emoticons/default/sheeplove.gif) something else. If it's not one thing, it's another. (Or as Freud put it: If it's not one thing, it's your mother.) |
McMark |
Apr 15 2010, 07:47 PM
The wiring harness has two connections. Let the other one dangle. It was already there, you just didn't notice it before.
jt914-6 |
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Is the wire connected to the master cyl. switch brown with a yellow stripe? It should be connected to it if your switch has a reset button. On the orignal switch there were two wires. The "ground" you think you disconneted is solid brown and IS a ground, except with the one wire switch it is not used...connects to nothing....
flipb |
Apr 15 2010, 08:04 PM
You all overestimate me.
I actually did screw up, I think. See below. It looks like the solid brown ground wire was clipped by a PO, presumably when the 19mm MC was installed. The brown/yellow stripe is the one I accidentally knocked loose. Anybody have a good photo to show where it connects? Alternately, is the risk of driving just that I won't get a warning light if I lose hydraulic pressure? |
McMark |
Apr 15 2010, 10:11 PM
Hooks onto that big white thing.
Attached image(s) |
Eric_Shea |
Apr 15 2010, 10:38 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
No, no, no...
It hooks on right here: There should be a male spade on the back of the tie-rod end there. (IMG:style_emoticons/default/huh.gif) Geez Mark... full of bad advice today aren't we? (IMG:style_emoticons/default/w00t.gif) |
McMark |
Apr 15 2010, 10:49 PM
Eric_Shea |
Apr 15 2010, 10:50 PM
(sorry... couldn't help myself) (IMG:style_emoticons/default/biggrin.gif)
Dave_Darling |
Apr 15 2010, 11:41 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The electrical connection is on the same thing that the reset button was on. Looks like that white thing in the pic is it, but I could be mistaken.
If you want to be sure, remove the gravel pan so you can get a good look at everything. Maybe put the front end up on jackstands (so we know it's a real 914!) so you can really get a look. --DD |
McMark |
Apr 16 2010, 10:48 AM
I'll be sure to bring my folding chair to WCR! (IMG:style_emoticons/default/chair.gif) HINT: You'll be the blue guy! |
Lo-Fi Version | Time is now: 26th June 2024 - 04:12 AM |
